Door switch
Lars65
Door switch
#1 Post by Lars65 » 02 Oct 2015, 07:08
I have tried to set up the ESP01 as a door switch. I can see that the ESP is working, but I can't get the Domoticz to work.
I have created a virtual switch, and from the virtual swittch added a sensor. Programed the ESP01 in the web interface with the IDX from the virtual switch. But there is no action in the domoticz.
What am I doing wrong here?
Do I need to add som script to the virtual sensor?
casi99
Re: Door switch
#2 Post by casi99 » 02 Oct 2015, 09:17
there can be many blocking points:
1.can you see in the ESPeasy if it shows the right status of the switch? (right GPIO, Pullup)
2. do you have put in Domo the switch online?
br
Carsten
2xESP8266 Olimex dev. board for testing
5xESP8266-01 for dimmer, switches, relays
2xESP8266-12E for relays and dimmer
maluko
Re: Door switch
#3 Post by maluko » 02 Oct 2015, 09:50
hi
Did you put the Esp01 IP on domoticz definitions?
espeasy dont have field to put the user and pass to acess domoticz so you have to add manualy.
Domoticz >setup > settings > Local Networks (no username/password)
Lars65
Re: Door switch
#4 Post by Lars65 » 02 Oct 2015, 10:43
Thank you guys!!
It was the network configuration in Domoticz, which did the trick.
Now it's working like a charm.
:D
Users browsing this forum: Bing [Bot] and 15 guests
