Display update via rules
cratsch
#1 Post by cratsch » 22 Nov 2016, 22:29
Hi guys,
I set up a rule as follows:
On Switch#State do
  If [Switch#State]=1
    oled,7,1,on
  Else
    oled,7,1,off
  Endif
This updates my OLED nicely to show "on" when I push the button "Switch", and when I release it, the display shows "off". BUT, next time I press the button, the display shows "onf" because it only overwrites the first 2 characters.
I don't want to work with the "clear" command because there's other stuff on the display that would disappear. And adding a whitespace in the rule behind "on" has no effect. Any ideas?
costo
Re: Display update via rules
#2 Post by costo » 25 Nov 2016, 00:18
cratsch wrote:Hi guys,
On Switch#State do
  If [Switch#State]=1
    oled,7,1,on
  Else
    oled,7,1,off
  Endif
If you put the whitespace in front of the text, like: " on" and "off" it will work as intended.
Users browsing this forum: Anthropic Claude Bot [bot] and 26 guests
