Relais Problem
Dylantje
Relais Problem
#1 Post by Dylantje » 10 Oct 2016, 20:53
Dear all.
Use multiple ESP with different sensors, GREAT work for this cheap board!!
I use the espeasy icw Domoticz [ always the last beta ]
1 problem.
I use 1 esp nodemuc for the control of my pellet stove.
Almost perfect.
1 problem, the relais i give the Http command like in the wiki.
http://<ESP IP address>/control?cmd=GPIO,<pin>,0
http://<ESP IP address>/control?cmd=GPIO,<pin>,1
Stange thing the ESP is switching some times multiple times, the relais board?
And the esp is switching in Domoticz 1 second. [
Only this second is to long.
Is there perhaps a option to switch the Http command with milliseconds?
Like:
Short pulses
To send a pulse to a certain pin:
http://<ESP IP address>/control?cmd=Pulse,<pin>,<state>,<duration>
Example to send an active high pulse on GPIO 2 for 500 mSeconds:
http://<ESP IP address>/control?cmd=Pulse,2,1,500
Only i do not need the pulse, i need only the switching time...
Or are there better options?
mgennip
Re: Relais Problem
#2 Post by mgennip » 10 Oct 2016, 22:01
/control?cmd=pulse,12,1,500
switches GPIO12 to 5volts for 500ms
Works fine for my Dru fire place
Dylantje
Re: Relais Problem
#3 Post by Dylantje » 10 Oct 2016, 22:06
mgennip wrote:/control?cmd=pulse,12,1,500
mmm
And is he switching auto off then?
Or how do set this in Domoticz?
With a relais?
Dylantje
Re: Relais Problem
#4 Post by Dylantje » 11 Oct 2016, 21:13
mm did try this no luck @ all.
How is your config?
Edit.
When i set my Relais in the ESP as button low or as switch. [ and in Domoticz 1 sec off ]
Sometimes my relais is going on and off servel times. While i push 1 time @ the button...
hvdwolf
Re: Relais Problem
#5 Post by hvdwolf » 21 Oct 2016, 22:24
It sounds as if you configured a device in EspEasy as input switch. That even gives strange effects with your relais (trust me. I had the same).
Simply remove that switch device from Esp Easy and control your gpio pin from your domoticz frontend via the gpio 0/1 command. No device needed on the EspEasy.
Dylantje
Re: Relais Problem
#6 Post by Dylantje » 26 Oct 2016, 21:26
hvdwolf wrote:It sounds as if you configured a device in EspEasy as input switch. That even gives strange effects with your relais (trust me. I had the same).
MMM sorry no time to react
This looks a solution...
Only very strange ...
Do you have perhaps to switch this relais for les then 1 second???
I try to switch my pelletstove...
1 sec is 3 degrees higher... :-(
Thanks for the support..
hvdwolf
Re: Relais Problem
#7 Post by hvdwolf » 06 Nov 2016, 19:16
A late reaction as I hoped someone else more experienced would have reacted.
To start with: if you switch on the relay it will stay on until you switch it off again.
So my guess:
As you want to be very precise in how long you wantthe relais to be switched on I would not access the relay directly in this case. I would try to send a value (no. of seconds) to a variable on your EspEasy. Via the rules system and using the TimerSet command I would try to switch on the relay for x seconds.
Or set a GPIO pin high. Check that pin via an event (rules) and switch on the relay, and set GPIO low again.
As I can't try this I hope that someone with more experience will react on this and confirm it or give a better solution.
hvdwolf
Re: Relais Problem
#8 Post by hvdwolf » 06 Nov 2016, 19:42
I forgot something: You can use the pulse command.
http://www.letscontrolit.com/wiki/index.php/GPIO
Dylantje
Re: Relais Problem
#9 Post by Dylantje » 07 Nov 2016, 01:15
hvdwolf wrote:I forgot something: You can use the pulse command.
mw
When i do that the relais stays on open....
There is no off command...
hvdwolf
Re: Relais Problem
#10 Post by hvdwolf » 23 Nov 2016, 08:40
Yes there is
The first one is the off command (sets pin to low/off), the second is the on command (sets pint to high/on)[/i]
Edit: Sorry. wrong answer.
The pulse sets the pin high for a specific amount of time. This should therefore also set the pin to low again after the pulse.
If this really doesn't work then it is probably a bug in the software. Please also mention the esp easy version you are using.
however, you still didn't mention whether you removed your device which works as an input switch.
This definitely does not work and gives all kind of strange actions. I had the same issue where I had configure a switch in the esp and where my pin remained in high/on position.
Remove the switch device in the Esp software: did you do that?
Dylantje
Re: Relais Problem
#11 Post by Dylantje » 24 Nov 2016, 20:52
I did use espeasy buttons in the esp.
Only you say that have to remove this, and that works much better, the gpio direct command.
Only still i have a react time of 2-3 seconds...
and still the pelletstove is going to high when i push the button.
I did buy a SSR relais on ebay only not @ home:
http://www.ebay.com/itm/5v-1-Channel-SS ... Sw44BYIaIn
Perhaps faster
DeNB3rt
Re: Relais Problem
#12 Post by DeNB3rt » 13 Dec 2016, 14:38
Dylantje wrote::-)
Perhaps faster
Hi Dylantje
Did you receive ur SSD relay?
I'm very interested in the experience with it :-).
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 10 guests
