esp8266 newbie problems
jimd
#1 Post by jimd » 25 Nov 2016, 02:51
Just loaded espeasy using the ide it starts fine, but showss nossid even though i set it in the sketch. am i missing something?
jimd
Re: esp8266 newbie problems
#2 Post by jimd » 25 Nov 2016, 04:28
Figured that out. Now I cannot get domoticz to connect. The instructions I saw were to create a a dummy switch in domoticz, and use that ID in the espeasy setup page. I have done that, but domoticz still thinks I have a switch.
Also tried as a temp/humid sensor, and it sticks at 32 degrees F.
jimd
#3 Post by jimd » 07 Dec 2016, 22:22
Bump. Still not working?
DeNB3rt
#4 Post by DeNB3rt » 08 Dec 2016, 12:48
jimd wrote:Figured that out. Now I cannot get domoticz to connect. The instructions I saw were to create a a dummy switch in domoticz, and use that ID in the espeasy setup page. I have done that, but domoticz still thinks I have a switch.
Dummy hardware device is ok, but you have to create dummy sensors by clicking in the hardware tab on 'create dummy sensor', then you can choose the correct sensor.
The IDX from that sensor (in tab devices) should be used in ESPEasy.
jimd
#5 Post by jimd » 15 Dec 2016, 17:06
I've attached photos of my setup. What am I missing?
NightBird
#6 Post by NightBird » 16 Dec 2016, 00:02
Hi jimd,
you're using the wrong value (14065) for IDX. This is an internal value used by Domoticz (named ID on top of column).
You have to use the IDX value (second column), which in your case is 21.
It should work, now... ;)
Users browsing this forum: Anthropic Claude Bot [bot], Bing [Bot] and 14 guests
