I am using an LCD display with an I2C converter together with ESP Easy. Everything is working fine.
But now I want to ad a proximity sensor which turns on the display when somebody is in front of the display.
Is it possible to switch of the backlight of the display?
Gr. Remco
Can I control the backlight of an I2C LCD display?
Re: Can I control the backlight of an I2C LCD display?
Sure, you need to connect backlight pin to a GPIO and use rules...rhannink wrote:Hello,
Gr. Remco
Backlight can be switched off by your controller using the following http: command:
http://<ESP IP address>/control?cmd=lcdcmd,off
more info can be found on the espeasy wiki pages.
http://www.letscontrolit.com/wiki/index.php/LCDDisplay
Users browsing this forum: Ahrefs [Bot] and 12 guests
