Http to domoticz (json) syntax problem
qwerk
#1 Post by qwerk » 26 Nov 2016, 16:51
I want to use rules to signal when my esp has booted.
I want him to switch a (virtual) light on
I use:
On System#Boot do
SendToHTTP 192.168.3.119,80,/json.htm?type=command&param=switchlight&idx=1759&switchcmd=On
I get:
On System#Boot do
SendToHTTP 192.168.3.119,80,/json.htm?type=commandśm=switchlight&idx=1759&switchcmd=On
It can't handle the &param .
Does anyone knows a way around this?
ayasystems
Re: Http to domoticz (json) syntax problem
#2 Post by ayasystems » 27 Nov 2016, 20:06
You can create one switch and set it to send the value AT BOOT.... It is the same that you are talking
qwerk
#3 Post by qwerk » 27 Nov 2016, 20:37
ayasystems wrote:You can create one switch and set it to send the value AT BOOT.... It is the same that you are talking
thanks, simple and effective
I didn't think of that
Users browsing this forum: No registered users and 5 guests
