ESP-01 and BMP085/BMP180 sensor
tOmki
#1 Post by tOmki » 29 Sep 2015, 14:57
Hi, how to connect ESP-01 and BMP085/BMP180 sensor.
A need to define something in ESP Easy firmware ?
BertB
Re: ESP-01 and BMP085/BMP180 sensor
#2 Post by BertB » 30 Sep 2015, 15:39
You do not need to define anything in the software.
For the ESP-0,1 do not use a version above 20.
Once active, select in the hardware tab, via web interface a port for the SDA and one for SDC.
Connect the BMP accordingly.
You can check the connectivity in the Tools tab, with the I2C scanner.
After that, create a task in Devices and off you go.
tOmki
#3 Post by tOmki » 30 Sep 2015, 20:50
thx :]
Dlanor
#4 Post by Dlanor » 18 Nov 2016, 16:23
BertB wrote:You do not need to define anything in the software.
I have followed the steps and the BMP180 get detected. I have added the BMP180 to devices but unfortunately i get no readings. I am using a ESP8266 ESP-12E board with R145_RC6.
Raspberry Pi (2x) | RFXCOM RFXtrx433E USB | RFlink | Landis+Gyr ZME120ACd | USB-IR-Schreib-Lesekopf | Alecto WS1500 | Touchscreen | Yooda Sunscreen | Google Nest | Piface| kWh meter| DS18B20 | BMP180 | ESP8266 ESP-12E
BertB
#5 Post by BertB » 18 Nov 2016, 23:49
Did you also enter a number in the IDX/Variable column?
Dlanor
#6 Post by Dlanor » 28 Nov 2016, 10:17
BertB wrote:Did you also enter a number in the IDX/Variable column?
Have done! but didn't work.
BertB
#7 Post by BertB » 28 Nov 2016, 16:36
Did you enter something like 60 in Delay?
Did you use GPIO 4 and 5 for something else?
Perhaps you need a capacitor accross VCC and GND of the BMP.
Do you have pull up resistors on SDA and SCL?
Users browsing this forum: Anthropic Claude Bot [bot] and 17 guests
