Temperature and humidity values from ESP8266 are not seen in Domoticz temperature widget
loicwyn
#1 Post by loicwyn » 28 Nov 2016, 17:06
I received my ESP8266 with BME280 sensor I connected to Domoticz running on a Raspberry pi2.
I see the temp, humidity & barometer values properly updated on ESP8266 and sent to my Raspberry over JSON.
I also see on Domoticz, the temperature graphic is properly recording the temp & humidity values over the time:
Screen Shot 2016-11-28 at 17.03.13.png (139.77 KiB) Viewed 2389 times
All is good so far but the issue is with the temperature widget itself not providing the latest temp & humidity values (on the top-right side of the widget) :
Screen Shot 2016-11-28 at 17.03.00.png (21.29 KiB) Viewed 2389 times
Do you know what shall be done to fix it ?
loicwyn
Re: Temperature and humidity values from ESP8266 are not seen in Domoticz temperature widget
#2 Post by loicwyn » 30 Nov 2016, 17:38
This was a setup issue. I fixed it by used a temp+hum+bar virtual sensor in domoticz instead of temp+hum
