I have a set of Chacon EMW200 plugs that I would like to control. In the supported hardware, I see Chacon (excluding EMW200) and the next line mentions Chacon (including EMW200)... The release notes also seem to mention support for EMW200 but it doesn't seem to work in the end.
Here is a log output of ON then OFF :
10;rfdebug=on;
20;5B;RFDEBUG=ON;
20;5C;DEBUG;Pulses=50;Pulses(uSec)=1170,510,1290,300,390,1200,1260,360,360,1230,390,1230,330,1230,360,1260,330,1260,1230,360,330,1260,1200,390,330,1290,1200,390,300,1290,1200,390,300,1290,1200,390,300,1290,1200,390,300,1320,1170,420,1170,420,1200,450,270,6990;
20;5D;DEBUG;Pulses=50;Pulses(uSec)=360,1290,1200,420,300,1320,1170,420,270,1320,270,1320,270,1320,270,1320,270,1320,1170,450,240,1350,1140,450,240,1350,1170,450,270,1350,1140,450,240,1350,1140,450,240,1350,1140,480,240,1350,1140,450,1140,450,1140,480,240,6990;
20;5E;TriState;ID=0a0aaa;SWITCH=2;CMD=ON;
20;5F;DEBUG;Pulses=50;Pulses(uSec)=360,1320,1170,420,270,1320,1170,450,270,1320,270,1320,270,1320,270,1350,270,1350,1170,450,270,1350,1140,480,240,1350,1140,450,240,1350,1140,450,240,1350,1140,450,240,1410,1110,450,240,1350,1140,450,1140,450,1140,480,240,6990;
20;60;DEBUG;Pulses=50;Pulses(uSec)=330,1320,1170,450,270,1350,1170,450,240,1350,270,1350,240,1350,1140,450,240,1350,1140,450,240,1350,1140,450,240,1350,1140,480,240,1350,1140,480,240,1350,1140,480,210,1380,1140,480,240,1350,1140,480,1110,480,1110,480,210,6990;
20;61;DEBUG;Pulses=50;Pulses(uSec)=870,810,1290,300,420,1200,1260,330,390,1230,360,1230,330,1260,330,1260,330,1230,1230,360,330,1260,1230,360,330,1290,1200,390,300,1290,1200,390,300,1290,1200,420,300,1320,1170,420,300,1290,1200,420,300,1320,270,1320,270,6990;
20;62;DEBUG;Pulses=50;Pulses(uSec)=390,1290,1200,420,300,1320,1200,420,270,1320,270,1320,270,1320,270,1320,270,1320,1170,450,270,1350,1170,450,240,1320,1170,450,240,1350,1140,450,240,1350,1140,480,240,1350,1140,480,210,1350,1140,450,240,1350,240,1350,240,6990;
20;63;TriState;ID=0a0aaa;SWITCH=2;CMD=OFF;
20;64;DEBUG;Pulses=50;Pulses(uSec)=360,1320,1170,420,270,1320,1170,420,270,1320,270,1350,240,1350,1170,450,270,1350,1140,450,240,1350,1140,450,240,1350,1140,480,240,1350,1140,450,240,1350,1140,480,240,1350,1140,450,240,1350,1140,450,1140,480,1140,480,210,6990;
Do you think there is any way to make it work?
Chacon EMW200
Re: Chacon EMW200
It looks like the remote is detected correctly:
Re: Chacon EMW200
The remote commands seem to be detected... But the commands sent by RFLink don't have any effect on the plug. I use Domoticz and the setup is working fine with some other plugs (old Perel plugs).
Re: Chacon EMW200
Any news about this?
I'm waiting for a RFLink and have 9 chacon EMW200RC... they work fine with my RFXTRX433... Did you ever got them working with the RFLink?
Best,
Gustavo Melo
Best,
Gustavo Melo
Re: Chacon EMW200
This should be fixed in the next release..
Re: Chacon EMW200
Hi, Bonjour,
Have you news for the topic ?
i just buy a RFLink and I have a lot of ChacOn EMW200RC.
Have you a date for the new release with the bug fixing ?
Thanks for your support.
Amitié , Michel.
Domoticz on RPI3 and RFLink/Arduino
Amitié , Michel.
