I am trying to get the ESP8266-12 running on my own board. I am using the current beta firmware (R143 I guess) and I don't have any problems when I don't use the sleep mode.
Concerning the Hardware, I have a 12k pull-up connected to the RESET-Pin. If i additionally connect the GPIO16-pin to the RESET-pin, the chip is stuck in reset (looks like because the current consumption is increased and it does not connect to the WiFi). It does not change if sleep mode is enabled or disabled in the web-interface....
Is this a known problem? How do I fix it?
Many thanks in advance for any hint to get rid of this problem
