Rules when disconnected
JustmeNL
#1 Post by JustmeNL » 09 Dec 2016, 23:19
I'm using espeasy R140 on a couple of sonoff devices with Domoticz and MQTT. I really love this software!
I created two devices: a manual switch and a dummy output for MQTT.
The output is on GPIO 12 and the switch (Push button active low) on GPIO 0.
My rules are simple:
on Manual#Switch do
  if [Manual#Switch]=1
      GPIO 12,1
      Publish domoticz/in, { "idx": xxx, "nvalue": 1 }
      GPIO 12,0
      Publish domoticz/in, { "idx": xxx, "nvalue": 0 }
The idea is that the switch works regardless of whether Domoticz is working. However I found that when de WiFi is down the rules are not processed.
Are there any plans to change this or did I make some mistake here?
yarysek
Re: Rules when disconnected
#2 Post by yarysek » 10 Dec 2016, 21:57
I have the same,
Instead using Publish command i use SendToHttp but have same problem, commands operate with a large lag or even not.
I think this is because Esp waiting for repeat from domoticz.
I thinking to use some thing like If function.
If connected do
SentToHttp....
But i don't have any idea now.
If you find any solution give me know about that.
yarysek
#3 Post by yarysek » 07 Jan 2017, 11:59
nobody can help us?
ToniA
#4 Post by ToniA » 07 Jan 2017, 15:03
I made a small code change to have a new event called 'System#MQTT': viewtopic.php?f=6&t=2431&p=11886#p11886
You can use this event to reset a timer, and then do something if the timer ever fires.
Users browsing this forum: Bing [Bot] and 15 guests
