ESPEasy Mega - Pulse counter values
nick-head
#1 Post by nick-head » 27 Dec 2016, 11:59
Hi All,
Does anyone know if you can send separate time values to Domoticz that were obtained by the Pulse Counter.
I see Delta, Delta/Total/Time and Total only. I need the Time values only and can't find how to do it.
I have tried all combinations but no luck, I may be missing something really simple.
I am using the value for a kW meter to show kW's used at that time, it woks on the OLED but cannot send
it to Domoticz.
Nick
ESP32, Arduino's,Raspberry Pi's, ESP8266's, Nextion's, Sonoff's, LightWaveRF's, RFXCom 433, and a headache
And a HackRF One, as a present to myself.
nick-head
Re: ESPEasy Mega - Pulse counter values
#2 Post by nick-head » 27 Dec 2016, 16:49
Thanks for the help.
Had to do a re-write on the source-code, but, it works.
[img]
[/img]
nick-head
#3 Post by nick-head » 27 Dec 2016, 18:34
Yay, finally, and it talks to Domoticz as I intended to do in the first place.
These forums are good arn't they .
papperone
#4 Post by papperone » 27 Dec 2016, 20:24
great job! woudl you mind to share the code/plugin you used??
nick-head
#5 Post by nick-head » 27 Dec 2016, 20:45
I am using the ESPEasy-Mega Version 147 Experimental.
This code replaces the original Pulse Counter within the source code.
I am not even sure I modified it in the correct way / legal code and the like, however it is working
as I want it for now, don't know about long term, but it's the best I can do because the help wasn't
too forthcoming.
I will mod it later to create it's own plugin and re-instate the original Pulse Counter for compatibility.
Maybe some-one later on in the future will do a proper plugin, or give me a few tips on what
actually to do as I haven't got much of a clue other than experimentation.
nick-head
#6 Post by nick-head » 27 Dec 2016, 22:59
Iv'e changed it over to Plugin P012 now, so it can run with P003.
If anyone wants to mess about with it and make it better.
vojtishek
#7 Post by vojtishek » 02 Oct 2018, 15:10
Hi, where I can find a plugin please and how to setup domoticz?
Basically I would like to measure time when my termostat light is on and put formula in espeasy to get wattage.
Then send to domoticz.
Help appreciated.
Vojta
Users browsing this forum: Semrush [Bot] and 11 guests
