Support for variuos ESP8266 relay boards
sovking
#1 Post by sovking » 28 Dec 2016, 13:39
Hi guys,
I would like to know if anyone has tried to install ESPeasy on any of the following board:
They are working ? any issues ?
moelski
Re: Support for variuos ESP8266 relay boards
#2 Post by moelski » 29 Dec 2016, 08:21
Hi !
http://www.ebay.com/itm/ESP8266-220V-10 ... 2150587112
https://www.olimex.com/Products/IoT/ESP ... e-hardware
Should work. But as always ... You should know the schematics of the board.
Getting ESPEasy running is not the Problem ...
http://www.ebay.com/itm/DC-5V-12V-Jog-s ... 2240346088
http://www.ebay.com/itm/AC-220V-WiFi-Wi ... 2240345737
This don´t look like ESP8266 stuff. So I assume this will not work.
regards
Dominik
sovking
#3 Post by sovking » 29 Dec 2016, 10:08
moelski wrote:Hi !
I need just to know which gpio switch the relay, because that's is my main use case.
The olimex board seems well documented and with the schematics where I see that the relay is linked to GPIO5.
The drawback are that is a little bit pricey and that the power is at 5V fixed, but I hope that it will be more reliable and better designed with respect to other esp8266 boards. I'll try it.
For the other board on that announcement I found some documentation too, the cost is similar but the input is variable 7-30Vdc.
moelski wrote: http://www.ebay.com/itm/DC-5V-12V-Jog-s ... 2240346088
Regarding this two board I tought that they are ESP8266 stuff because in their page it is shown that such board are supported by eWeLink App which is the app used by ITEAD Sonoff stuff.
I don't know if such application is written for different hardware or works only with esp8266.
Another clue, for the board "DC-5V-12V-Jog-self-lock-Smart-WiFi-Wireless-Switch-Relay-Module-APP-Control" is that the schematic seems the same of this board: https://www.itead.cc/smart-home/motor-r ... witch.html
apart the single relay. Of course the ITEAD board is cheper and works for sure.
Users browsing this forum: Anthropic Claude Bot [bot] and 19 guests
