I have a problem with flashing espeasy to a nodemcu board. I have tried both flashing with arduino ide and esptool.py, both seem to flash correctly but on boot I get INIT : Incorrect PID or version!. Esptool.py gives pid and version 0 and arduino PID:4294967295 Version:-1.
I have tried erasing flash but it doesn't help.
Any suggestions?
Also, is there some documentation on what special tricks the esptool accompanied with espeasy does?
Flashing problem (nodemcu)
Re: Flashing problem (nodemcu)
try this flasher : https://github.com/nodemcu/nodemcu-flasher (Win32 or Win64 release)
I had problems for flashing with included flasher, but this one seems to work as expected.
Good luck
Good luck
ESPEasy running on ESP-12F self-made modules (with various sensors) and talking to Domoticz (hosted on RPi2)
I don't have windows.
But I changed from nodemcu 1.0 to 0.9 from arduino ide and it worked after that. My board says nodemcy v3.
But I would still like to know whats the difference between the boards, apparently some flashing parameter needs to be different?
