we are a small german company dedicated to building things. We came from the web development industry but shifted our interests more and more to embedded development. We've developed different customer solutions like power measurement systems, digital signage solutions and even a scoreboard for a footbal club using mqtt and other techniques.
As a side project, we've developed and designed our own access control based on beaglebone black and AVR microcontroller devices using SHA1 iButtons, which is nearly finished now. This was done together with a PCB specialist which is one of our contractors.
More an more customers come to us and ask for integration of home automation devices. One of the biggest issues are the sensors you need to automate your home. Beginning this year we've discovered espeasy and use it in custom build sensors with mainly i2c temperature and humidity sensors, the DS18B20 is still in the business
We've also experimented with battery driven devices which use the espeasy sleep mode, as the biggest problem is to not dig up the walls to lay new cables. So why not use an existing infrastructure as easpeasy does? Wi-Fi!
The idea is to build buyable dedicated hardware with an integrated charging circuit for a rechargable and replaceable battery in a nice form factor with pluggable sensor modules. Maybe for the first run only one type of sensor. All this packaged in a nice case with a high WAF and without any need for a power adapter (but optional). An optimised antenna circuit and maybe an external antenna is one of our ideas. With a sleep time of maybe 15minutes this device should run 3-6 months.
Also we would like to open this up as much as possible. We are planing to integrate a button for flashing and pins for RX/TX so you can repogramm it or use your own firmware. As I understand it right the licenense of espeasy allows this.
My question now is, is there any interest for such a device? How much were you willing to pay?
I try to understand if it will be a good idea to invest time in this and start manufacturing on the long run.
Would be very kind to hear from you...
Cheers,
Patrik
