GPIO state on reboot
albertobonati
#1 Post by albertobonati » 13 Dec 2016, 15:49
I noticed this happen:
- If I set "Pin mode" of pin 2 as LOW in GPIO boot state this work fine, I reboot my ESP 01 and after some second GPO2 go LOW state.
- If I add a switch device, after reboot GPIO2 is always HIGH, doe not matter I set "Send Boot state" on or Off, "send data" on or off...
If i send on/off command from domotic it work fine...
This on ESP 01 - Build 120
Some suggestion?
Alberto
toffel969
Re: GPIO state on reboot
#2 Post by toffel969 » 08 Jan 2017, 20:32
Can you maybe use Rules to set it to desired state with onboot event?
