I get the following after flashing with R32
>>>stack>>>
3ffec8f0: 00000002 4000410f 3ffec930 40216a66
3ffec900: 3fffc718 40004a3c 0000011c 0011c000
3ffec910: 3fffc718 40101fe0 0000011c 40216d60
3ffec920: 0000011c 40207d58 0000011b 40207d7f
3ffec930: 3fff5048 0000000f 0000000f 40216058
3ffec940: 3fffdc20 3ffeca10 3ffeca10 3ffec9dc
3ffec950: 3fffdc20 3ffeca10 3ffea8a4 40207de1
3ffec960: 402019da 00002710 00002710 3ffec9dc
3ffec970: 3fffdc20 3ffeca10 3ffea8a4 4020a7bc
3ffec980: 00000000 00000000 00000000 00000000
3ffec990: 00000000 00000000 3ffec9d4 4020255f
3ffec9a0: 00000000 00000000 3ffeb990 40100374
<<<stack<<<
ets Jan 8 2013,rst cause:1, boot mode:(3,2)
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
ªU0
0
INIT : Incorrect PID or version!
Will not run after R32 Update
Re: Will not run after R32 Update
i´ve got no problems, but uses more ESP-12E with 4 MB Flash.
Bernd
Bernd
Also on a E12
Working for me to
DS18B20 now working with normal values, before always 4095.94 degrees
Had much trouble by updating to a previous release.
I think the ESP8266 not always reset totally when flashing new software, but hold some data at some memory locations.
Had to do many resets and uploading before it worked normal.
Not sure if it has anything to do with ESPEasy
Working for me to
i had a little bit problems at and up V030, but i´m thinking thats because i´m using the 3 "problem" (GPIO 0, 2 and 15) ports.
Bernd
Bernd
Users browsing this forum: Ahrefs [Bot] and 19 guests
