&param bug on rules
fabix68
&param bug on rules
#1 Post by fabix68 » 15 Jan 2017, 16:10
Even with the latest firmware remains the bug with the word "&param" which is converted to ¶m.
You may not be able to correct it?
aprex
Re: &param bug on rules
#2 Post by aprex » 15 Jan 2017, 21:10
Yes, please, it will be fine to send alerts to Domoticz, instead of waiting 5 minutes for a device refresh...
Martinus
#3 Post by Martinus » 16 Jan 2017, 09:34
It seems that if &para is shown somewhere in a webform, the &para is interpreted as the HTML escape sequence for a paragraph sign, looking like a backwards P.
I don't know where it should be fixed and it's possible that it does not occur on all browsers.
But there's a workaround for this particular bug: Use the &param as the first name-value pair in the URL so it becomes ?param and it will no longer be misinterpreted.
Example:
change this:
sendtohttp 192.168.0.8,8080,/json.htm?type=command&param=udevice&idx=286&svalue=%eventvalue%
into:
sendtohttp 192.168.0.8,8080,/json.htm?param=udevice&type=command&idx=286&svalue=%eventvalue%
So we've just changed the order in which the url is build up.
aprex
#4 Post by aprex » 16 Jan 2017, 15:57
Thanks Martinus, no more bad characters!
fabix68
#5 Post by fabix68 » 16 Jan 2017, 22:14
Thanks Martinus
Jeff
#6 Post by Jeff » 16 Jan 2017, 22:33
Thanks Martinus, cool :D
ayasystems
#7 Post by ayasystems » 18 Jan 2017, 12:53
COOL!
Users browsing this forum: Bing [Bot] and 19 guests
