French Elec Counter : Teleinformation
In france we got some specifique french counter.
we can get ll information by using serial connection and a SH620 a light relay switch.
In domoticz we must use : TeleInfo edf USB device.
all exemple found will be in french of course.
Once here : 5 Way of work :
1 - Buy an expensive serial adapter
2 - Made one serial adapeter with an arduino wire connected (http://www.domotique-info.fr/2014/05/re ... n-arduino/)
3 - Made a facke OWL180 433 mhz with an arduino and an rf tx : http://domotique.web2diz.net/?p=11
4 - plug wire via SFH620A to rx / tx on a raspberry : http://www.magdiblog.fr/gpio/teleinfo-e ... lectrique/
5 - Use Mysensor : https://github.com/jaysee/teleInfo
It does looks like Easyesp can't does this is this plan ?
Re: French Elec Counter : Teleinformation
I am pretty sure you can use the counter feature and connect the optocoupler to the ESP8266, like in the Arduino and Raspberry Pi examples.Deennoo wrote:In france we got some specifique french counter.
This is very similar to people using phototransistors to measure power from a flashed LED on their smartmeter
- Jan
Jan Chrillesen, Denmark
We use it to converte signal to a normal serial signal, we do not counter anything, that with we have to use rx and tx on the rpi plug.chrille wrote:I am pretty sure you can use the counter feature and connect the optocoupler to the ESP8266, like in the Arduino and Raspberry Pi examples.Deennoo wrote:In france we got some specifique french counter.
- Jan
Counter send information about which period of day we are (high price or low price), index (high and low), actual consumtion
French elec counter is know as smart p1 counter
I've done a SI7021 plugins, looking at the very well writed code of ESPEasy, see http://www.esp8266.nu/forum/viewtopic.p ... 7021#p1265
So now, I think It can be easy to add teleinfo, I'm waiting from core to be updated to be able managing serial plugins
I can be your tester !
Yes me too i'm really interested !
I get a solution without EasyEsp :https://hallard.me/wifinfo/
For domoticz intégration :http://easydomoticz.com/forum/viewtopic.php?f=7&t=843
Users browsing this forum: Ahrefs [Bot] and 13 guests
