mhoek
#1
Post
by mhoek » 03 Nov 2015, 22:05
When i connect a single ds18b20 temperature sensor to an ESP8266 with ESPEASY R39, the temperature is measured with a 12-bit accuracy. When i connect multiple sensors on one GPIO or multiple GPIO's, the accuracy of the temperature reading is lowered to 9-bits. In some cases the first sensors still have a 12-bit accuracy, but the last sensors have 9-bit.
Do you have any idea if this is a bug, or a feature
mhoek on 23 Jan 2017, 21:16, edited 1 time in total.
smagghe
#2
Post
by smagghe » 03 Nov 2015, 22:26
You can test this version of the dallas plugins. With the one you can set the resolution (accuracy).
please tell me if it's ok and working for you.
- _P004_Dallas.zip
- (4.32 KiB) Downloaded 570 times
rmtucker
#3
Post
by rmtucker » 03 Nov 2015, 22:37
I have multiple sensors running on one esp8266 with no problems.
But i recently bought a few on ebay which would only work in 9bit mode (I think they were fakes).
Luckily the seller returned my money.
mhoek
#4
Post
by mhoek » 04 Nov 2015, 07:17
smagghe wrote:Hello,
Thanks, I'll try.
I'm pretty sure the accuracy of the sensors isn't the problem, when i was running my own program, the temperature readings were ok.
vmfs1968
#5
Post
by vmfs1968 » 04 Nov 2015, 12:32
I see if my DS18B20 is working the 9-bit or 12?
mhoek
#6
Post
by mhoek » 05 Nov 2015, 07:21
Works like a charm!!
mhoek
#7
Post
by mhoek » 23 Jan 2017, 21:07
Hi there, the plugin you suggested has one minor bug: Every reboot, the resolution must be set again to 12-bits.
I've noticed this plugin isn't compatible with R120. Do you have another version of the plugin that is compatible with R120??
mhoek
#8
Post
by mhoek » 24 Jan 2017, 20:25
I have made the following changes to plugin _004
Plugin_004_DS_reset();
Plugin_004_DS_write(0x55); // Match ROM command
for (byte i = 0; i < 8; i++)
Plugin_004_DS_write(ROM[i]); // ROM selection
Plugin_004_DS_write(0x4E); // Write Scratchpad
Plugin_004_DS_write(0x00);
Plugin_004_DS_write(0xFF); // set 12-bit resolution
delay(50);
The code above has been inserted before :
Plugin_004_DS_write(0x44); // Convert T
delay(800);
I think some of my sensors have been programmed in 9-bit resolution before. This was the most easy fix i think.
