Need a Build R20 With all
asm7100
#1 Post by asm7100 » 12 Oct 2015, 14:18
Need a Build R20 with all the goods up to Build (Last one)
5xESP-01 - 3xESP-12 - 2xESP-12E 3xRPIb+ - 1xBPIm1 - 3xACTi DOME - 7xACTi Indoor cam. Lot off cisco equ.
BerndJ
Re: Need a Build R20 With all
#2 Post by BerndJ » 12 Oct 2015, 19:44
asm7100
#3 Post by asm7100 » 12 Oct 2015, 21:23
Yes I know, but the newest one is from 2015-09-13. :-) And even that has a lot of bugs.
rtenklooster
#4 Post by rtenklooster » 13 Oct 2015, 20:06
asm7100 wrote:Yes I know, but the newest one is from 2015-09-13. :-) And even that has a lot of bugs.
A lot of bugs?
Currently i'm using 8 esp modules in my whole house. None of them is showing any bug.
Richard - Groningen (NL) - Image
asm7100
#5 Post by asm7100 » 13 Oct 2015, 20:20
how about DS18B20 showing minus degrees?
More than one DS18B20 how does that work. ?
But now R39 works.
rtenklooster
#6 Post by rtenklooster » 13 Oct 2015, 20:51
asm7100 wrote:how about DS18B20 showing minus degrees?
But now R39 works.
I still don't see how this means: "a lot of"
For as far as i can see it's one bug you're pointing out.
A quote from the wiki:
"The ESP Easy firmware is currently in alpha stage where we're working on design, functionality and stability."
It's not a problem you're talking about issues, that's why we are here.. to help each other and to make the esp code more stable and more useful.
But a lot of bugs... that's way to negative for as far as I can judge.
BertB
#7 Post by BertB » 14 Oct 2015, 12:55
I second that. ESP Easy is very stable from my point of view and I am very happy with it.
