How to control 4 channel relay with button and MQTT
Hello guys I'm new to Esp Easy is it possible to control 4 channel relay board with esp8266 esp(12F) control it with MQTT and add 4 physical buttons to control this relays.?
Re: How to control 4 channel relay with button and MQTT
yesashfaaaa wrote:Hello guys I'm new to Esp Easy is it possible to control 4 channel relay board with esp8266 esp(12F) control it with MQTT and add 4 physical buttons to control this relays.?
How did you do to revert the GPIO state ?
Using the rules (EspEasyMega) I'm not able to read the GPIO state to revert the state of the relay...
In my case, I want to use the same ESP to read the input and control the relay using a specific rule.
Thanks !
Thanks !
Have you read the wiki tutorials regarding rules?
Yes, I have try reading the Rules Tutorial.
I want to do anything like that :
But it seem not possible to read a GPIO used as output...
on Button#State=1 do
If GPIO14#State=1
gpio,14,0
Else
gpio,14,1
Endif
guslinux wrote: ↑07 Jan 2018, 20:55 Yes, I have try reading the Rules Tutorial.
I want to do anything like that :But it seem not possible to read a GPIO used as output...Code: Select all
on Button#State=1 do If GPIO14#State=1 gpio,14,0 Else gpio,14,1 Endif endon
on Button#State do
If [Button#State]=1
gpio,14,0
Else
gpio,14,1
Endif
In my case,
I have 3 push button connected to the esp (on the same input), and I want also change the output state with a On/Off command using a domotic box (using MQTT).
I want to use rules to had more reactivity than using the domotic box to do that.
I want to use the less input possible on my esp (regarding your proposal to connect the relay output ton an input to monitor)...
So funnel all these inputs to the same event? You may use dummy devices to store the state.
Users browsing this forum: Anthropic Claude Bot [bot] and 23 guests
