New RFLink firmware (R46) now available!
Check here: http://www.nemcon.nl/blog2/
R46: (10/03/2017)
- New Device: Applidom DM82 motion sensor
- New Device: OWL Intuition PV / CM180i
- New Device: WH2A temperature sensors
- New Device: WH1285 TX (WH-5) Temp & Humidity sensor
- New Device: ABB lightswitch type 3299a-11900 (a.k.a. TX Tango) (Receive only!)
- New Device: Velleman VM130T Motor control
- New Device: HRC 101 Motor control
- New Device: AC512-02 AC to RF projection screen trigger
- New Device: 2 new Dooya protocol flavors
- New Device: D-YA / Diya Motor control
- New Device: Konx doorbell model 602 (Receive only!)
- New Device: Doorman doorbell (Receive only!)
- New Device: Acurite 3in1 3N1TXR / 3N1TXC (Thanks: JR)
- New Device: Byron BY532E (Receive only!)
- New Device: Stagnoli remotes
- New Device: Blyss temperature sensors (Ref.630467) (Thanks: JD)
- New Device: Grundig QH-831A 2010525 & Quhwa QH-831A doorbell
- New Device: 868mhz: Woonveilig security sensors
- New Device: 868mhz: Egardia security sensors
- New Device: 868mhz: Alecto WS3900
- New Device: Yale HSA3000/6000 alarm system sensors
- New Device: Sartano 50080 (Harald Nyborg 2794) switch set
- New Device: Astrell 85 portal motorization system
- New Device: Philips AJ7010/12
- New Feature: Learn RF device signals that use a standard EV1527/PT2262 protocol
- Fixed: Some small eeprom handling issues
- Fixed: Improved AI protocol priority handling
- Fixed: various CC2500 issues, make sure pin 6 is wired to ground to use CC2500!
- Fixed: Tightened Warema EWFS detection
- Fixed: RTSlongTX command
- Fixed: ON/OFF vs UP/DOWN command handling
- Fixed: UPM Esic extended packet detection and increased sanity checks on data
- Fixed: Optimized Novatys timing
- Fixed: AlectoV3 Humidity value validation
- Fixed: FineOffset vs Alecto improved differentiation, Note: device ID's have changed for WS1100
- Fixed: Alecto WS-1100 humidity
- Fixed: AlectoV4 Some packets contained an invalid temperature
- Fixed: Globaltronics GT-WT-02 negative temperature/channel number mixup
- Fixed: Globaltronics GT-WT-02 now always reporting a humidity
- Fixed: Tristate send, removed debug message and fixed a timing bug
- Fixed: WS7000 rain reporting
- Fixed: Added additional Brel protocol variant
- Fixed: LightwaveRF turned MOOD commands into regular switch commands so any home automation software can use them
- Fixed: Improved Friedland doorbell signal detection
- Fixed: Acurite 5in1 corrected wind speed, wind direction and rainfall values (Thanks: Xztraz.)
- Fixed: Improved AcuRite 00592TXR detection
- Fixed: Tunex zero humidity value
- Fixed: Improved Home Confort transmit routine and added up/down support (Thanks: Geert)
- Fixed: Battery detection in Prologue protocol
- Fixed: Added channel number to device ID for THGR810
- Fixed: Added channel number support to Warema devices
- Fixed: Improved UPM ESIC protocol detection
- Fixed: Improved SA33 detection
- Fixed: Gaposa protocol timing
- Added: battery status on various Alecto/Maplin devices (Thanks: Ad)
- Added: Hardware & Software configuration via i/o pins:
pin 6 to ground for: CC2500 enable
pin 7 to ground for: disable internal pull-up on RF data in
pin 12 to ground for: reset of EEPROM settings
R46: (10/03/2017)
Re: New RFLink firmware (R46) now available!
Nice changelog! Thanks, works like a charm
Witch modul use for 868 mhz???
Aurel RTX MID 868 transceiver
Aurel RX-AM8SF receiver
Awesome! Donated a little bit for all the hard work with the weather sensors.
Tnx!
Cool. Now FineOffset is FineOffset again, but with an extra 0x30xx added to ID, as a bonus I also got a bunch of outdoor sensors reporting a static 99 humidity
Care to share the secrets behind:
///Redferne
Explanation can be found here:
http://www.nemcon.nl/blog2/faq#RFFind
chacon emw200 still doesn't work, nor the CM180i:
144 rfxcom 9800 0 Owl Intuition Energy CM180 4293.700 kWh
3 rfxcom 9800 0 Energia Current Current/Energy CM180i 23 Watt, 23 Watt, 322 Watt, Total: 4293.700 kWh
632 RFLink 00000098 1 OWL_Intuition General kWh 0.000 kWh
633 RFLink 00000198 1 OWL_Intuition General kWh 0.000 kWh
634 RFLink 00000298 1 OWL_Intuition General kWh 0.000 kWh
635 RFLink 00000398 1 OWL_Intuition General kWh 155.048 kWh
Both have been tested and are working.. for the Chacon you need to use the rffind option..
Well, regarding the cm180i, this is what domoticz gets (RFXCom and RFLink):
144 rfxcom 9800 0 Owl Intuition Energy CM180 4295.385 kWh 7 100 2017-03-14 00:55:54
3 rfxcom 9800 0 Energia Current Current/Energy CM180i 23 Watt, 23 Watt, 437 Watt, Total: 4295.385 kWh 7 100 2017-03-14 00:55:54
632 RFLink 00000098 1 OWL_Intuition General kWh 0.000 kWh - - 2017-03-14 00:55:54
633 RFLink 00000198 1 OWL_Intuition General kWh 0.000 kWh - - 2017-03-14 00:55:54
634 RFLink 00000298 1 OWL_Intuition General kWh 0.000 kWh - - 2017-03-14 00:55:54
635 RFLink 00000398 1 OWL_Intuition General kWh 155.425 kWh - - 2017-03-14 00:55:54
turn the rffind mode on; pressed ON/OFFF on domoticz on two switches configured with RFXCom and saved the following:
RF Record: 0 ID: 445557 S: 0E L: 2E T: 01 - ON
RF Record: 1 ID: 445554 S: 0E L: 2E T: 01 - OFF
RF Record: 2 ID: 451557 S: 0E L: 2E T: 01 - ON
RF Record: 3 ID: 451554 S: 0E L: 2E T: 01 - OFF
Now the rflink gets the switches on domoticz as RFCustom, but they don't work... I tried using the remote but get the usual:
10;rffind=on;
20;FD;RFFIND=ON;
20;FE;TriState;ID=045aa2;SWITCH=3;CMD=ON;
20;FF;TriState;ID=08a2aa;SWITCH=2;CMD=OFF;
20;02;TriState;ID=088aaa;SWITCH=2;CMD=OFF;
20;03;TriState;ID=088aaa;SWITCH=2;CMD=ON;
Am I missing something?
TIA
Gustavo Melo
RFcustom does not work on stable release I think, have to use beta, can that be the problem?Gusimelo wrote: ↑14 Mar 2017, 02:17Well, regarding the cm180i, this is what domoticz gets (RFXCom and RFLink):
For the EMW200 I tried the rffind this way:Code: Select all
144 rfxcom 9800 0 Owl Intuition Energy CM180 4295.385 kWh 7 100 2017-03-14 00:55:54 3 rfxcom 9800 0 Energia Current Current/Energy CM180i 23 Watt, 23 Watt, 437 Watt, Total: 4295.385 kWh 7 100 2017-03-14 00:55:54 632 RFLink 00000098 1 OWL_Intuition General kWh 0.000 kWh - - 2017-03-14 00:55:54 633 RFLink 00000198 1 OWL_Intuition General kWh 0.000 kWh - - 2017-03-14 00:55:54 634 RFLink 00000298 1 OWL_Intuition General kWh 0.000 kWh - - 2017-03-14 00:55:54 635 RFLink 00000398 1 OWL_Intuition General kWh 155.425 kWh - - 2017-03-14 00:55:54
10;rffind=on;
20;FD;RFFIND=ON;
TIA
Gustavo Melo
Yes, you for sure need beta..
Hi there
I am pretty new to this but I managed to install r45 with no problems. When I Download r46 there is no RFlink.cpp.hex. Only a RFLinkino.hex. Should I use that.
I use the nodo rflink gateway with nrf.
Regards Harry
Regards Harry
Yes, the filename changed and the included loader works fine with it too
I'm running the latest beta, still doesn't work
HI,
Since I have upgraded to this version, my Tristate switchs stopped working. I see the frame correctly detected using the remote but sending the same commands has no effect on the switchs . I know that some fix has been added for Tristate protocol but in my case it made my switchs not working anymore.
Anyway, had to roll back to R45 as I am not using the new features brought by R46, but could be usefull if a fix can be provided
Thanks for all the job done on this library!
Hi. After updating to R46, temp + hum device WTGR800 stopped working. I have two of those together with other type sensors, and only those two are not updating the values. Went back to R45 data started to update again.
WTGR800 is a Domoticz type.. it has no relationship to RFlink other than that it is a temperature sensor..
Possibly the ID has changed in R46.
Make a debug log and mail that to frankzirrone@gmail.com
