mcteusz wrote: ↑15 Mar 2017, 14:38
You need to change controller IP address in ESP config to your computer IP address where Domoticz is installed. 127.0.0.1 is loopback and it must be address in your LAN like 192.168.1.15 or 10.0.0.5. Run cmd and type: ipconfig /all
Hi @mcteusz thank you for reply. here is my ipconfig settings, which one is usually ?
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-BOU6D16
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : BC-EE-7B-9E-9C-88
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 24-05-0F-36-6B-B0
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Realtek RTL8192CU Wireless LAN 802.11n USB 2.0 Network Adapter
Link-local IPv6 Address . . . . . : fe80::5861:8cc2:41ef:9b1e%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.108(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, March 15, 2017 3:53:38 PM
Lease Expires . . . . . . . . . . : Wednesday, March 15, 2017 5:53:39 PM
Default Gateway . . . . . . . . . : fe80::a62b:b0ff:fecf:a93c%14
192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 153355535
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-16-37-7D-BC-EE-7B-9E-9C-88
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{BC1F7307-E56C-40F3-8038-AB7DD6932AB7}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:78cf:54:292c:3f57:fe93(Preferred)
Link-local IPv6 Address . . . . . : fe80::54:292c:3f57:fe93%13(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 134217728
NetBIOS over Tcpip. . . . . . . . : Disabled
