Getting Started - No data getting through to Domoticz from BME280 via ESPEasy setup
robatbentley
#1 Post by robatbentley » 18 Mar 2017, 22:27
I'm a total beginner trying to configure my first ESPEasy BME280 (temp, humidity and pressure) device using an NodeMCU ESP8266. The ESPEasy and BME280 end seems to be working as I'm seeing good data in my EPSEasy Device "values" summary. However, I don't have the knowledge to get this data displayed in my Domoticz web-page. I've followed some guidelines and created a dummy hardware followed by "Create Virtual Sensors" which are visible but the associated data just isn't being updated from ESPEasy.
Have I missed out some critical step here? I thought that I didn't need to write any code to get this working but may be wrong on this. I think I've configured my ESPEasy device correctly (screenshot attached) but guess something is wrong somewhere. I've also requested help from the Domoticz forum just in case the problem is a combination of issues.
Anyway, any help in getting my first ESPEasy-Domoticz project up and going will be greatly appreciated. ...and if more info is required then please ask.
RobUpNorth
paxi
Re: Getting Started - No data getting through to Domoticz from BME280 via ESPEasy setup
#2 Post by paxi » 20 Mar 2017, 01:04
Your controller IP is set to the loopback address - espeasy sends the data to itself. ;)
Users browsing this forum: Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 22 guests
