conecting to diode - check state
Jufo
#1 Post by Jufo » 20 Mar 2017, 11:40
Hi,I would like to check the status LEDs on the "other system" (common ground) when it is turned on and when it is turned off. How to connect and configure?
Voltage when it is switched on = 1,74 V
Voltage when it is switched off = -0,60V (meter error?)
I would like to plug in to GPIO09 or GPIO10. Eventually you to connect to the GPIO TX or RX (change the function gpio), "schema other system", marked in red LED:
Jufo
Re: conecting to diode - check state
#2 Post by Jufo » 20 Mar 2017, 17:14
Problem solved i use ADC.
#3 Post by Shardan » 20 Mar 2017, 21:37
if i may suggest anyways....
Replace the LED with an optocoupler.
It separates the ESP from your circuit reliably and can be read with a standard GPIO input.
paxi
#4 Post by paxi » 20 Mar 2017, 21:43
... or use the signal at the upper end of R736 (via voltage divider if >3.3V). ;)
Jufo
#5 Post by Jufo » 20 Mar 2017, 21:54
Thanks for the response,
I decided to leave on the ADC, I did not use it for anything, and here it works fine (for 1,74V shows 1024):
paxi
#6 Post by paxi » 20 Mar 2017, 22:05
Are you aware that ADC is designed for 1V max?
Jufo
#7 Post by Jufo » 20 Mar 2017, 22:16
paxi wrote: 20 Mar 2017, 22:05 Are you aware that ADC is designed for 1V max?
Thanks for the information. I thought the range is up to 3.3V.
What resistor to reduce the voltage to increase the range to 1.74V, what current is needed for the GPIO-ADC?
paxi
#8 Post by paxi » 20 Mar 2017, 22:34
Gpio's are 3.3V, ADC isn't. Google those abreviations and read the datasheet.
Inputs are high impedance - asking for current is the wrong question. ;)
Resistors:
https://www.google.de/search?q=voltage+ ... calculator
Jufo
#9 Post by Jufo » 20 Mar 2017, 22:49
Shardan wrote: 20 Mar 2017, 21:37 if i may suggest anyways....
Can I ask for an example of an optocoupler that would be suitable for use in this case? Is the output needed for a control transistor or can I directly connect to the gpio through 3.3V?
The LED is not removed.
#10 Post by Shardan » 21 Mar 2017, 21:16
Jufo wrote: 20 Mar 2017, 22:49
I assume a standardopto coupler as the 817 types should do (EL-817, LTV-817).
I've suggested a similiar circuit for another purpose here in the forum:
You may try to connect the Optocoupler's LED in parallel to the existing one, but that might not work depending on the different paramters of the two LEDs.
If you don't want to remove the existing LED you can do this:
Use a resistor (330 ... 680 Ohm) and connect it from the Out-pin 5/R736 / Collector of T704 connection point to the LED of the opto coupler pin1. Connect the pin 2 from the opto coupler to ground of the circuit.
The output side can be connected directly to the GPIO pin, a pullup resistor (4,7KOhm) is connected from the GPIO to 3,3V (NOT 5V!!!).
Jufo
#11 Post by Jufo » 25 Mar 2017, 10:19
It works (on GPIO 3), thank you :)
#12 Post by Shardan » 25 Mar 2017, 10:29
Anytime :)
Users browsing this forum: Anthropic Claude Bot [bot], Bing [Bot] and 14 guests
