Hi everyone,
I saw video when was introduced ability to on/off sonoff with manual switch connected to gpio14 and GND.
I was not succesfull on espeasy flashed sonoff.
Do you have any experience with that?
Goal is to implement sonoff next to wall switch to be able to control it from domoticz as well as change state via manual switch.
Vojta
Sonoff + wall manual switch
Re: Sonoff + wall manual switch
I´ve was able to use gpio14 for it but over the wifi and there is delay of course.
Could you please advise how to put script inside espeasy firmware to switch on/off light via manual switch with immediate reaction?
Your help much appreciated.
Thank you
Vojta
Thank you
Vojta
I have the same function in my ESP12. Try this:
A new Device:
Device: Switch Input
1st GPIO: GPIO 14
Pullup: X
Inverted: X
Switch Type: Switch
Switch Button Type: Push Button Active Low
Value Name 1: Pushbutton
Rules:
on Input#Pushbutton do
if [Input#Pushbutton]=1
event switchon
event switchoff
on switchon do
gpio 12,1
on switchoff do
gpio 12,0
A new Device:
1st GPIO: GPIO 14
Pullup: X
Inverted: X
Switch Type: Switch
Rules:
event switchon
event switchoff
on switchon do
gpio 12,1
on switchoff do
gpio 12,0
Thanks a lot, I will try and let you know.Mr Moose wrote: ↑25 Mar 2017, 21:47 Hello,
A new Device:
1st GPIO: GPIO 14
Pullup: X
Inverted: X
Switch Type: Switch
Rules:
event switchon
event switchoff
on switchon do
gpio 12,1
on switchoff do
gpio 12,0
If you use a standard wall switch configure "switch button" type to "normal switch". Just to be safe wire a 1k resistor in series with the switch.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 12 guests
