RFLink mini GPIO problem.
About receivers, transmitters, transceivers, connections, antennas etc.
costo
#1 Post by costo » 08 Apr 2017, 18:44
Today I flashed RFLink R46 into my mega2560 which is connected to a RasberryPi with Domoticz. Until now I used R39 which did well for me.
When reading the faq of R46 release I was triggered by this part http://www.nemcon.nl/blog2/faq#GPIO
I have a special use for these 4 INPUT pins together with a receiver decoder on 315MHz, like this one: http://www.ebay.nl/itm/122154594503?_tr ... EBIDX%3AIT. This receiver-decoder has 4 Data outputs and a output called ´Data Valid´.
I happen to have a few 4 button 315MHz remotes and think this can perfectly be integrated with RFLink/Domoticz using the new R46 GPIO feature.
But ........
Something seems to be wrong, I cannot trigger pin 26,27,28 or 29 by making it high or low.
RFLink does not generate a message like this:
20;1A;GPIOset;ID=0;SWITCH=0;CMD=ON;
20;1B;GPIOset;ID=0;SWITCH=0;CMD=OFF;
I do not see it nor in the ArduinoIDE_monitor, nor in Domoticz.
I checked allow new hardware/Devices in the Domoticz setup.
But no response, what can be wrong ?
Related question is:
I tried from within the IDE-monitor the command: 1O;GPIOset;30;0;ON & OFF and that actually works, I can turn on/off a led.
But .... how can I generate a command like this from within Domoticz to trigger one of the OutputPins D30......D39
Stuntteam
Site Beheer
Re: RFLink mini GPIO problem.
#2 Post by Stuntteam » 08 Apr 2017, 21:21
Did you enable the minigpio?
what does command
10;status;
tell you?
costo
#3 Post by costo » 08 Apr 2017, 21:39
20;01;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
setGPIO=OFF that must be the reason
think ..... think ...... for a few ninutes.
solved: Command 10;setGPIO=ON;
It is working now
