433 MHz Transmitter & Receiver
BerndJ
#1 Post by BerndJ » 23 Oct 2015, 11:49
3 Cables, one 433 MHz Sending Modul and one ESP, and it´s running fine: :)
https://alexbloggt.com/funksteckdosenst ... t-esp8266/
The used library also supports receiving.
best wishes
BerndJ
asm7100
Re: 433 MHz Transmitter & Receiver
#2 Post by asm7100 » 24 Oct 2015, 06:43
Sorry to ask, what the point?
Don't speeak german.
And the Wifi modul ja has Wifi?
5xESP-01 - 3xESP-12 - 2xESP-12E 3xRPIb+ - 1xBPIm1 - 3xACTi DOME - 7xACTi Indoor cam. Lot off cisco equ.
NietGiftig
#3 Post by NietGiftig » 28 Oct 2015, 09:07
Nice one
I will try if the el-cheapo switches (Impuls Action) are working with this.
It is sort of RFXcom but much cheaper.
Switching these devices with MQTT (node-red) would be nice
@asm7100.
See it as an interface between wifi and 433mhz stuff.
BerndJ
#4 Post by BerndJ » 28 Oct 2015, 11:02
Hi NietGiftig,
".. if the el-cheapo switches (Impuls Action)....".
Did u had a link?
The used chip in the transmitter is a HX2262, normally designed for IR Remotes.
U can recogniced them at the 5 DIP Switches in the transmitter, i thought these parts are the lowest-cost on the market.
best wishes
BerndJ
asm7100
#5 Post by asm7100 » 28 Oct 2015, 12:43
aaah ok :-) nice
Ger
#6 Post by Ger » 28 Oct 2015, 16:50
I use RFLink to control 433 Mhz devices with domoticz and it works very nice :D
http://www.nemcon.nl/blog2/
I hope for a version with 433 Mhz and 866 Mhz together ;)
Greetings,
Ger
NietGiftig
#7 Post by NietGiftig » 28 Oct 2015, 18:08
BerndJ wrote: ".. if the el-cheapo switches (Impuls Action)....".
Did u had a link?
http://forum.arduino.cc/index.php?topic=38075.0
The problem with the el cheapo switches is that they all have slightly different timings
http://wiki.pilight.org/doku.php/impuls
I believe that the impuls switches use an LP801
Ger wrote: I use RFLink to control 433 Mhz devices with domoticz and it works very nice :D
I have also the rflink, but unfortunately the Impuls switches are not working.
The developer has some timing problems, but he is working on it.
But with the rflink you also need to buy an arduino mega and it takes an USB port on the Raspi.
If you can use the ESP8266 and an simple transmitter it is cheaper.
And you can make very simple for every floor in the house an 433mhz access point witch is accesseble with Wifi (browser/app/...).
Ger
#8 Post by Ger » 28 Oct 2015, 20:27
I completely agree with you. ;)
It would be cheaper and it would also solve the problems when having different floors.
It would also make it easy to make an 866 Mhz version.
Greeting,
Ger
rtenklooster
#9 Post by rtenklooster » 29 Oct 2015, 10:10
I wouln't count to much on extended wireless support on the esp easy.
The RFLink is the perfect device for all wireless communication. Esp devices are cheaper, but come on... on Aliexpress.. what does a arduino mega Costs you? William, the developer of the RFLink is one of the best wireless protocol developers / reverse engineers. If there are timing issues with cheap ass action receivers he will fix it if that's possible. It might be questionable whether the few euro's per device will make a lot of difference given the fact that at Bauhaus 3 switches + 1 receiver (KaKu) will cost you about 21 euro's. Good quality widely support and proven stability.
Besides all that, the origin of this project lays in the nodo project, using nothing else then 433Mhz communication. The problems we where facing at that point where besides heavy use of this band, distortion, security and range issues, where the reason the developers looked at alternatives.
So yes, i agree a little support for wireless 433 communication might come-in handy, e.g. i have some 433 range issue's. If i could have one esp module capable of sending kaku signals when receiving a http command, it might be handy. As some kind of smart "repeater" (without repeating, just as a de-central sender). I will place that device on the second floor to be sure the signal is received.
Richard - Groningen (NL) - Image
NietGiftig
#10 Post by NietGiftig » 29 Oct 2015, 13:46
rtenklooster wrote:I wouln't count to much on extended wireless support on the esp easy.
ah, inside information, thanks
Nevertheless it's a pity, but it is your project as i understand, so you have every right for this decision.
rtenklooster wrote: The RFLink is the perfect device for all wireless communication.
And so there is wireless and wireless.
RFLink does not do wifi but has to be connected with USB to the HA server.
So "all wireless communication"is not completely true.
I understand that you like the work of William, that's alright so!
I have had some mail exchange with him and he is very helpful.
But at the moment my switches do not work with RFLink
rtenklooster wrote:Besides all that, the origin of this project lays in the nodo project, using nothing else then 433Mhz communication. The problems we where facing at that point where besides heavy use of this band, distortion, security and range issues, where the reason the developers looked at alternatives.
Yes but I'm perfectly happy with my exsting switches (there working good with their own controller and with other projects with Arduino's) so I don't want to throw them away because of all the problems you describe.
So the combination of WiFi (ESP8266) and Arduino code for the 433mhz part is nice for me if it works.
Combining the old and the new until the old has aged to much, and that without investment.
rtenklooster wrote:So yes, i agree a little support for wireless 433 communication might come-in handy,
Ah, Glad you agree to that!
Deennoo
#11 Post by Deennoo » 30 Oct 2015, 23:26
This can be usefull to extend 433 range.
I'm using RFLink since his beginning, i try to help by testing more and more new plug ins and try to made supports for french people.
I'm facing a problèmes : my wind sensor is an Oregon and RFLink can't get it because he is too far (on house roof), i need still use my rfxtrx just for this wind sensor.
If Esp can be place on half way to catch RF signal and translate it via wifi to my PI it will be perfect !
NDR008
#12 Post by NDR008 » 01 Feb 2018, 20:55
OpenMQTTGateway or mqtt433gateway on GIT have that almost solved.
First uses RC-Switch to decode, the second uses pilight.
The second is working better for me still teething out issues though.
Users browsing this forum: Bing [Bot] and 17 guests
