Can someone give a tip?
I before in the version as 148 or lower
Made an update to the via ota without problems
Now with this new reset data every time
......................Update Success: 546336
Rebooting...
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
@cp:0
ld
øªU
INIT : Booting version: (v2.0.0-dev8)
FS : Mount successful
Resetting factory defaults...
RESET: Cold boot
FS : formatting...
FS : formatting done...
FILE : File saved
FILE : File saved
Factory reset succesful, rebooting...
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
øªU
INIT : Free RAM:27752
INIT : I2C
INIT : SPI not enabled
WIFI : No SSID!
WIFI : No SSID!
INIT : Rebooted from deepsleep
WD : Uptime 0 ConnectFailures 0 FreeMem 22048
esp8266 v2.0.0-dev8
Re: esp8266 v2.0.0-dev8
can you give some details please?
- is a controller (domoticz, FHEM, openHAB.....) connected?
- Are sensor values reported to the controller?
- Some special things configured? (Rules, GlobalSync...)
- which hardware do you use (WeMos, nodeMCU...)
- does it reboot immediately or does it run for some time and reboots then?
That might help to help you
The hardware is a wemos
Update via usb = ok
Update via ota = reset and delete all settings
The old version did not do this
With the file created in Arduino
Update via usb = ok
Hello again,
updating from the R1xx to the 2.00 versions will delete all settings due to internal changes, thats correct.
When flashing a 2.0.0 over a 2.0.0 the settings will stay as they did with the R1xx versions.
It should not make much diofference if you compile on Arduino or PlatformIO.
Did you use the sources from the zip file or did you download a zip from github?
Older zips from github might not work correctly.
I just downloaded a fresh zip, compiled it with PlatformIO and flashed it on a WeMOS, it runs nicely.
Does it reboot at once or does it run for a while and then stops/reboots?
