Hello EveryOne.
smagghe
Hello EveryOne.
#1 Post by smagghe » 01 Nov 2015, 23:56
Hello EveryOne,
My firt name is Gabriel.
I develop my domotic with Domoticz.
I've tried wired systems, 433Mhz and NRF24L01. But I don't know if my haouse was hunted, but nor DI.O (chaccon systems) they don't work perfectly.
So, I've decided to use a comfortabe network system : WIFI.
And the ESP8266 Be !!
With EspEasy & Domoticz, I can make a beautyful domotic system.
But I'm a mad developper and I already have Modified EspEasy :
- Correction for the Dallas 18B20 and add the resolution choice
- Add a relay plugin, for use with normal relay and Low state actived relay.
- working , to develop a plugin for the shift register 74HC595, but this task need to modify the core of EspEasy (add a third pin to the device structure)
Is there an other version than the R38 ? (before I' send to you my work)
Thank you a lot for your work.
Best regards
Gabriel
BertB
Re: Hello EveryOne.
#2 Post by BertB » 02 Nov 2015, 13:46
Hi, welcome here.
If you go to the github, you will find the latest versions.
smagghe
Re: Hello EveryOne.
#3 Post by smagghe » 02 Nov 2015, 23:00
Yes,
Ok...
Thank's for the answer....i see that after my post....oups !
smagghe
Re: Hello EveryOne.
#4 Post by smagghe » 02 Nov 2015, 23:27
Oh , I Forgot....I'm French. Also if my english isn't perfect, it's totaly normal.
here is my version of the P004 plugin for the dallas DS18b20 :
The code is in attachment.
_P004_Dallas.zip
(4.32 KiB) Downloaded 331 times
smagghe
Re: Hello EveryOne.
#5 Post by smagghe » 03 Nov 2015, 22:38
With the screen capture :
[attachment=0]Capture.jpg[/attachment]
Users browsing this forum: No registered users and 5 guests
