which way switches the relais on a sonoff basic while booting the fastest while using ESP Easy? Is there a possibility to manage this by the initial firmware? I used rules or gpio boot states.
But it is much slower than Tasmota with "PowerOnState on". But in this case this setting wasn't there after a while without power for the sonoff. Can I "config" this setting by editing a configfile (config_user.h)
Greetings
Thomas
Which way to switch a relais on boot
Re: Which way to switch a relais on boot
Hello Thomas
easiest way is using rules.
I've a sonoff basic in my office ceiling light and use a simple rule for that:
The advantage of that: I can switch light on with the standard wall switch in case of failure.
The disadvantage: It takes about 6 seconds until the sonoff boots up and the rule works.
I've tried some other things but they had some other quirks, flickering, blocking the remote control and such.
I try to avoid changing sources as with the next update i surely have forgotten i changed it
Shardan (Aka Thomas
On System#Boot do
gpio,12,1
Shardan (Aka Thomas
Hello again,
try using gpio boot states. This way is much faster then the rules. Perhaps there is a other faster way using ESP-Easy.
Using Tasmota would be better for me. I use a POW also. Maybe another has a idea how to configure the default state of the relais while booting.
Untill now (without KNX) I want to use the common electric wires. If I want to switch the lamp on, 4-6 sek are too long for getting an reaction of the lamp. This would't be accepted by my wife.
Users browsing this forum: Anthropic Claude Bot [bot], Bing [Bot], OpenAI GPTBot [bot] and 23 guests
