Having trouble connecting ESP node to Domoticz controller
orbitcoms
#1 Post by orbitcoms » 24 May 2017, 05:44
I have a DS1820 temperature node on 192.168.1.15. The Domoticz is hosted on Raspberry pi 3 (port 8081). The pi has 2 Wifi adapters (Wlan0 on 192.168.1.161, wlan1 on 192.168.1.162).
Wlan0 is the pi built-in wifi
Wlan 1 is a USB wifi dongle
AP is an ESP8266 set up as softAP - ssid = "TemperatureNetwork"
If I navigate to either of the pi wifi URL, I get the Domoticz screen and all is ok.
I can access the node OK (192.168.1.15)
I have set up the node to connect to wifi on Wlan1 (ssid = "TemperatureNetwork" and set the psk accordingly.
In the controller page I have set up Domoticz HTTP, IP address 192.168.1.162, port 8081 and ticked to enable then saved.
Then I set up the DS1820 and it is working fine. But, the node does not seem to connect to the Domoticz controller and I am not sure what steps to take next to resolve this.
Here is a dump of the ESP node coms output. You can see that is gets the temp ok but fails to deliver.
INIT : Booting version: v2.0.0-dev8
FS : Mount successful
INIT : Free RAM:27472
INIT : I2C
INIT : SPI not enabled
WIFI : Connecting... 1
WIFI : Connected! IP: 192.168.1.15
INIT : Normal boot
WD : Uptime 0 ConnectFailures 0 FreeMem 24288
WD : Uptime 1 ConnectFailures 0 FreeMem 24152
WD : Uptime 1 ConnectFailures 0 FreeMem 24016
FILE : File saved
FILE : File saved
WD : Uptime 2 ConnectFailures 0 FreeMem 23920
FILE : File saved
FILE : File saved
FILE : File saved
FILE : File saved
FILE : File saved
FILE : File saved
FILE : File saved
FILE : File saved
WD : Uptime 3 ConnectFailures 0 FreeMem 23536
FILE : File saved
FILE : File saved
FILE : File saved
FILE : File saved
FILE : File saved
FILE : File saved
WD : Uptime 3 ConnectFailures 0 FreeMem 22664
DS : Temperature: 23.50 (28-ff-f7-9f-91-16-5-3e)
HTTP : connection failed
Users browsing this forum: Ahrefs [Bot] and 17 guests
