#51
Post
by Shardan » 24 May 2017, 13:55
Dylantje wrote: ↑23 May 2017, 22:13
Did swap... [ not with my wife
No luck..
To get it straight:
"No luck" says it's the same circuit with another sensor going crazy?
The most strange thing.
I did a test setup..
Works for weeks... [ in my garage ]
After a hard reset because i set something wrong..
This strange thing is happening..
How did you hard reset? Tx/Rx shortened? Sent a "Reset"?
Dylantje
#52
Post
by Dylantje » 24 May 2017, 14:16
Shardan wrote: ↑24 May 2017, 13:55
No luck..
To get it straight:
Everything the same on the outside
And try different/ other pir. use 1 pir that works on the working system...
tx/rx connected...
toffel969
#53
Post
by toffel969 » 24 May 2017, 15:31
Dylantje wrote: ↑24 May 2017, 14:16
No luck..
To get it straight:
tx/rx connected...
Direct sunlight?
Dylantje
#54
Post
by Dylantje » 24 May 2017, 19:56
Direct sunlight?
That is the only thing different...
mmm that's shoeld be nasty.....
1 pir have dig a cable to the door for this pir...
GGRRRRR
Perhaps with a 10K between..
The strange part. test works great...
luisfcosta
#55
Post
by luisfcosta » 24 May 2017, 22:49
I wanted to provide a follow up and closure to my previous plea for help
Situation: Espeasy R120 not stable, causing nodelink R8 to reboot every 10 secs. Espeasy loaded with Arduino source code. Board was also not reacting on MQTT commands.
Solution:
Upgraded to 147 RC8 using the flash.cmd method.
I can now control my relays using one of the following:
mosquitto_pub -t "{devicename}/gpio/16" -m "1" [or "0"].
mosquitto_pub -t "{devicename}/cmd" -m "GPIO,16,1"
mosquitto_pub -t "{devicename}/cmd/gpio/16" -m "1"
My MQTT broker receives the same message, so I am able to keep track of what is ON of OFF and bridge this to other systems (in my case, SmartThings)
At least the board is able to listen to the broker and the board is now stable.
I had some hiccups with Openhab MQTT mode, where the board would loose connection with the broker, but so far great.
Now my next challenge is to send a more user-friendly command such as:
mosquitto_pub -t "{devicename}/LivingRoomLight/switch" -m "1" [or "0"].
I just don't want to deal with the GPIO mapping!
Any hints?
The documentation is not rich on this matter. I am sure others have the same struggle.
#56
Post
by Shardan » 24 May 2017, 23:46
sorry i have to pass on that one... i'm not using MQTT at all.
Users browsing this forum: Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 14 guests
