MCP23017 GPIO PIN CONFIGURATION
vuhams
#1 Post by vuhams » 08 Jun 2017, 10:40
MY DESIGN
In my project i used MCP23017 and i connected 8 switches from port 1 to 8, and i connected relay driver ULN2003 to drive 12v relay from the port 9 to 16. The hardware am using is ESP-12E with espeasy firmware 2.0.10 (latest). ESP-12E I2C is GPIO4 and GPIO5
PROBLEM
1. Relay connected with MCP will not respond as quick when i pressed the switch.
OBSERVATION
I checked the source of the firmware and came to a conclusion that, i have to configure 9-16 as OUTPUT.
REQUEST
So, I request everyone to help me
1. to configure MCP 1 - 8 PORT as INPUT and 9 to 16 as OUTPUT.
2. how to make MCP GPIOs respond as fast i press the switch
REFERENCES
ESPEASY Rules
On SW1#Switch=1 do
If [RL1#Switch]=1
mcpgpio,9,0
mcpgpio,9,1
Endif
On SW2#Switch=1 do
If [RL2#Switch]=1
mcpgpio,10,0
mcpgpio,10,1
Endif
On SW3#Switch=1 do
If [RL3#Switch]=1
mcpgpio,11,0
mcpgpio,11,1
Endif
On SW4#Switch=1 do
If [RL4#Switch]=1
mcpgpio,12,0
mcpgpio,12,1
Endif
On SW5#Switch=1 do
If [RL5#Switch]=1
mcpgpio,13,0
mcpgpio,13,1
Endif
//-END of RULES-
ESPEasy Devices
Task : 1
Device : Switch input - MCP23017
Port : 1
GPIO: GPIO-4 GPIO-5
Values: Switch: 0
Task : 5
Port : 5
GPIO: GPIO-4 GPIO-5
Values: Switch: 0
Task : 6
Port : 9
GPIO: GPIO-4 GPIO-5
Values: Switch: 0
Task : 10
Port : 13
GPIO: GPIO-4 GPIO-5
Values: Switch: 0
//-END OF DEVICE LIST-
___________________________
HAM Callsign: KD0NER
budman1758
Re: MCP23017 GPIO PIN CONFIGURATION
#2 Post by budman1758 » 09 Jun 2017, 08:38
Hello.
You do not need to define a task for the relay side of this unless you need to "read" the status of the relay. A task for the switch is enough to make it work. You will find yourself running out of tasks at 12 which is not enough for the MCP23017.
What kind of switch? Momentary or spst?
How long is it taking for the relay to react?
Are you also controlling the relays remotely?
I'm working on a project similar to yours using the MCP23017 also. Controlling remote lights with pushbutton switches and reaction time is at most a second or two. Works quite well.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 24 guests
