i need help im going to build a esp8866 esp-01 with a buzzer and a small lipo. im going to use this on my drone if i crash. i want to be avaible to connect my phone and then start the buzzer.
Ive only done esp easy to my sonoffs devices before. Is buzzers supported in esp easy?
Easp easy with buzzer?
Re: Easp easy with buzzer?
what type of buzzer were you thinking?
if its cheap buzzers I was thiknig of off ali all you would need is a relay and a buzzer
program it somehow if it crashes flip relay then it would turn on buzzer
It's a +and - buzzer only. I want to use my phone to activate the buzzer.
Is this hard to make? I can not code.
Sounds like a simple relay should work then?
If I use a transistor with active buzzer then I won't need a relay right?
Transistor will do, something like a 2N2222 or a FET like 2N7000.
