solved: Display Values
werner_g
#1 Post by werner_g » 11 Jun 2017, 14:29
I am a FHEM-user and publish sensor values via MQTT. For examples, I can see all published temperatur-values when checking the 'mqtt-spy'-tool. I would like to display these values in a ESP Easy-node using an OLED. Still using V1.47. Can anyone help me what I have to do?
Barb232
Re: Display Values
#2 Post by Barb232 » 11 Jun 2017, 18:37
hi,
i am using fhem too, and i wrote a short post in my blog.
It doesnt matter if its OLED or LCD1602
https://blog.moneybag.de/fhem-lcd-displ ... or-sds011/
Robin
werner_g
Re: Display Values
#3 Post by werner_g » 11 Jun 2017, 20:00
Hi Robin, so I need ESPEasy V2.0 (Mega) to import MQTT-values?! By-the-way, there are three different MQTT-protocols available (Domoticz, OpenHAB and PiDome). Is there any benefit to use Domoticz? I will upgrade to V2.0 tomorrow.
Barb232
Re: Display Values
#4 Post by Barb232 » 11 Jun 2017, 21:40
i am using Domoticz MQTT for this and it works.
i didn't find MQTT - Import in 147, so lets try the 2.0 dev 10 version.
Re: Display Values
#5 Post by Shardan » 11 Jun 2017, 22:14
If anything fails you can use FHEM's "notify" and send just a http command
http://<ESP IP address>/control?cmd=oled,<row>,<col>,<text>
There are commands for clearing and display on/off, see wiki.
https://letscontrolit.com/wiki/index.php/OLEDDisplay
werner_g
Re: Display Values
#6 Post by werner_g » 12 Jun 2017, 21:17
After upgrading to V2.10 I was able to display values out of the 'FHEM-universe'. Thanks for your tutorial, Robin! Now I can start my next project: combine FHEM & ESP Easy-devices with Node-RED.
Users browsing this forum: Ahrefs [Bot] and 21 guests
