Rules Event On and OFF
Guys,
I am stuck in my rules and do not understand where I am going wrong
From the page :
https://www.letscontrolit.com/wiki/inde ... ith_events
I have copied the full script and started to modify it a little.
Now the issue I am facing that I can start the event, but can not stop it #$%#$%@$#
I can start it with:
http://192.168.1.19/control?cmd=event,vuurtorenaan
But stop does not work:
http://192.168.1.19/control?cmd=event,vuurtorenuit
As you can see I have put an LED on GPIO 13. The led goes on and off per url request to go on and off. So the even on/off works.
I guess the issue is in the "timerSet,1,0" on the stop event. But as you can see the code is copied from the example page.......
Please advise or hint me in the correct direction ?
Goal :
To be able with a URL into ESP_EASY to start and stop a PWM slow on and off signal simulation a lighthouse light.
Many thanks for your time/help
Frank
This is my rules code :
//start the warning signal when we receive a start_warning event:
On vuurtorenaan do
timerSet,1,1
gpio,13,1
//stop the warning signal when we receive a stop_warning event:
On vuurtorenuit do
timerSet,1,0
gpio,13,0
//create an actual warning signal, every time timer 1 expires:
On Rules#Timer=1 do
//repeat after 2 seconds
timerSet,1,0.5
//pulse some led on pin 4 shortly
PWM,13,1024,1000
gpio,16,1
//Pulse,14,1,500
//produce a short 1000hz beep via a piezo element on pin 14
PWM,13,0,1000
gpio,16,0
From the page :
Goal :
Frank
On vuurtorenaan do
timerSet,1,1
gpio,13,1
On vuurtorenuit do
timerSet,1,0
gpio,13,0
On Rules#Timer=1 do
timerSet,1,0.5
PWM,13,1024,1000
gpio,16,1
//Pulse,14,1,500
PWM,13,0,1000
gpio,16,0
Re: Rules Event On and OFF
On vuurtorenuit do
timerSet,1,0
gpio,13,0
On vuurtorenuit do
gpio,13,0
timerSet,1,0
Hope it helps
You should not mix gpio and pwm commands to the same pin (because it does not handle well).
If pwm has been used on a pin, the gpio commands have no effect until you set pwm to value 0 before using gpio commands again...
Guys
Thanks for the quick reply.
I cleaned up my test code/rules. And stil having the same issue..
Can start with :
Can not stop with :
Would you be so kind to look after it again and advise me why my "vuurtorenuit" event does not stop the cyclus ?
My code
//start the signal when we receive a vuurtorenaan event:
On vuurtorenaan do
timerSet,1,1
//stop the signal when we receive a vuurtorenuit event:
On vuurtorenuit
timerSet,1,0
On Rules#Timer=1 do
//fade on led
PWM,13,1024,1000
//fade off led
PWM,13,0,1000
//repeat after 1 seconds
timerSet,1,1
Can start with :
Can not stop with :
My code
On vuurtorenaan do
timerSet,1,1
On vuurtorenuit
timerSet,1,0
On Rules#Timer=1 do
//fade on led
PWM,13,1024,1000
//fade off led
PWM,13,0,1000
timerSet,1,1
Hemmmmmmm
The below code does go on and off with the event on and off url
Only difference I see is that the timer is set to 600 instead of 1 sec.
Any hints ?
On startw do
gpio,13,1 //start watering (open valve)
timerSet,1,600 //timer 1 set for 10 minutes
On stopw do
timerSet,1,0 //timer 1 set to halt, used to stop watering before the timer ends!
On Rules#Timer=1 do
gpio,13,0 //stop watering (close valve)
endOn
Any hints ?
On startw do
On stopw do
On Rules#Timer=1 do
endOn
Yes, 1 second might be a bit fast and possibly is casing the timer to miss the trigger. We need to make a small passus about short time when using timer (on the wiki).
Hallo Freijn
Maybe a litle too late.
I think why it doesn't switch off is because of your PWM delays.
An ESP is a single threat processor.
While it is busy with PWM delay it cannot receive/handle other actions.
i didn't try but i had a same sort of issue.
Succes.
Gr Ernst
PS Wat voor soort vuurtoren schakel je aan en uit?
Succes.
Gr Ernst
Hi Ernst,
I will test your suggestion, many thanks !
If I send a reboot, it does switch off after all
The lighthouse is a plastic tower little over 1 meter hight. I have put an 12v super power led in it. Officially not dimmable but in a short span it does emulate the
lighthouse light effect of a light doing circles in the top of the tower.
Will let you know the results,
Frank
Frank
Ernst
I have made this one. Brute force hack, but it works (mind the reboot )
On start_warning do
timerSet,1,2
On stop_warning do
reboot
On Rules#Timer=1 do
timerSet,1,2
Pwm,13,1024,800
pwm,13,0,800
delay 300
On start_warning do
timerSet,1,2
On stop_warning do
reboot
On Rules#Timer=1 do
timerSet,1,2
Pwm,13,1024,800
pwm,13,0,800
delay 300
