SendToHTTP problem
BertB
SendToHTTP problem
#1 Post by BertB » 28 Jul 2017, 18:13
When compiled with #define PLUGIN_BUILD_TESTING, SendToHTTP 192.168.0.243,8080,/json.htm?type=command&param=switchlight&idx=293&switchcmd=On does not toggle the switch in Domoticz.
When compiled with #define PLUGIN_BUILD_NORMAL, it does work as expected.
Milifax
Re: SendToHTTP problem
#2 Post by Milifax » 31 Jul 2017, 11:38
BertB wrote: 28 Jul 2017, 18:13 When compiled with #define PLUGIN_BUILD_TESTING, SendToHTTP 192.168.0.243,8080,/json.htm?type=command&param=switchlight&idx=293&switchcmd=On does not toggle the switch in Domoticz.
Try:
#define PLUGIN_BUILD_TESTING, SendToHTTP,192.168.0.243,808,/json.htm?type=command&param=switchlight&idx=293&switchcmd=On
BertB
#3 Post by BertB » 02 Aug 2017, 18:46
Thanks for the hint.
Unfortunately, it makes no difference.
Users browsing this forum: Anthropic Claude Bot [bot] and 19 guests
