no wifi after espeasy flash, in sonoff touch
loosserman
#1 Post by loosserman » 06 Aug 2017, 19:24
hi!
i flashed sonoff touch with espeasy 120, the flahs finish without problems but after reboot no wifi esp_0 appears.
i repeat the process but wifi don´t work
Re: no wifi after espeasy flash, in sonoff touch
#2 Post by grovkillen » 06 Aug 2017, 20:41
That version is not ESP8285 compatible. You need the new (not yet official) version 2.0.0
Current build is "dev11".
https://github.com/letscontrolit/ESPEasy/releases
loosserman
#3 Post by loosserman » 06 Aug 2017, 21:23
i tryed with dev11 and dev10 wuth same result, flash finish correctly but after restart wifi dont appear :roll:
#4 Post by grovkillen » 06 Aug 2017, 23:13
Have you followed our wiki guide? Are you able to monitor the device over serial? Sometimes the device need some time to count in the version, have you let the unit boot for 10-15 minutes and then scanned the wifi? If that still doesn't do it you can reboot it and wait another 30-60 seconds before scanning the network.
PS. What bin file did you use? You need to use the file ending with "8285"
loosserman
#5 Post by loosserman » 07 Aug 2017, 11:59
thank you for the information!
i flashed with file ending "1024" , now with 8285 wifi works!!!
#6 Post by grovkillen » 07 Aug 2017, 12:29
Great news!
