Sonoff programming in bulk
femuruy
#1 Post by femuruy » 24 Aug 2017, 13:21
Hi guys, i went crazy and decided to add + 20 or 30 sonoff simple to my domoticz setup, the first batch of 10 are working like a charm w V120 but was wondering if it's ok if i modify the source and pre-add my wifi info and other stuff to speed up adding the 20 or 30 more i want in bulk? If so... what src files i have to edit and how do i get the img file to keep using esptool to upload it?
Thanks in advance for your time!
Re: Sonoff programming in bulk
#2 Post by grovkillen » 24 Aug 2017, 13:42
femuruy
#3 Post by femuruy » 24 Aug 2017, 15:08
Brillant :) need one more thing.... is there any way to control theese guys in domoticz by dhcp or i need to manually assign a fix ip for each node?
Thanks in advance!!!!!
#4 Post by grovkillen » 24 Aug 2017, 18:26
You would want to use MQTT for that. Search the forum and you'll find many uses of the plugin MQTT Import.
A more generic way might be on the horizon though:
https://github.com/letscontrolit/ESPEasy/issues/378
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Perplexity.ai [bot] and 16 guests
