LCD with two alternating sets of display lines?
manjh
#1 Post by manjh » 29 Aug 2017, 23:57
I am using an LCD screen with four display lines, and have run out of room.
It would be nice to have two separate sets of lines, which display alternating.
So first display the 1st set of lines, then after (say) 30 seconds display the second, etcetera.
I don't think this is a function at this moment, but would it be very difficult to do this?
toffel969
Re: LCD with two alternating sets of display lines?
#2 Post by toffel969 » 30 Aug 2017, 08:02
manjh wrote: 29 Aug 2017, 23:57 I am using an LCD screen with four display lines, and have run out of room.
I think this function is implemented in" framed LCD plugin"
Edit: it is the oled plugin not lcd.
Yo should be able to achieve the functionality with rules.
toffel969
#3 Post by toffel969 » 30 Aug 2017, 08:21
Yes it's possible. The commands shown under http control are also available in rules:
https://www.letscontrolit.com/wiki/index.php/LCDDisplay
Just use the lcd command in rules in combination with 2 timers.
manjh
#4 Post by manjh » 30 Aug 2017, 11:34
toffel969 wrote: 30 Aug 2017, 08:02
Ah, good idea! At system boot start timer1 with 30 secs, timer2 with 60. Then for each timer display the appropriate lines and restart the timer for 60 secs.
I think this will work, will play around with it a bit.
edit: tried it, and this works just great!
manjh
#5 Post by manjh » 30 Aug 2017, 11:38
toffel969 wrote: 30 Aug 2017, 08:21 Yes it's possible. The commands shown under http control are also available in rules:
Understand. But that would put the control in Domoticz (in my case), and I would prefer an ESP that is not depending on that.
I'll go for the "rules" solution and see where that brings me.
manjh
#6 Post by manjh » 30 Aug 2017, 12:20
One last question, is there a list of commands?
In the ESPEasy command reference I find a link to the LCD Display page, and there I can see four:
simple write, clear, on and off.
Is there more? Such as line-clear, blink on/off, cursor position?
toffel969
#7 Post by toffel969 » 30 Aug 2017, 15:54
manjh wrote: 30 Aug 2017, 12:20 One last question, is there a list of commands?
Not that I'm aware of. What do you mean by dependant o domoticz, it's all in in rules
#8 Post by Shardan » 30 Aug 2017, 19:34
As far as i can see from the code there are no further commands.
manjh
#9 Post by manjh » 31 Aug 2017, 09:55
toffel969 wrote: 30 Aug 2017, 15:54
Not with the http control commands, right?
Anyway, I tried the rules solution and that works very nice.
manjh
#10 Post by manjh » 31 Aug 2017, 09:57
Shardan wrote: 30 Aug 2017, 19:34 As far as i can see from the code there are no further commands.
Pity. Clearlline would have been useful, especially when I use text of varying length. If a displayed lline is shorter than the previous, it will leave some of the old text visible. The only options now are to either clear the whole screen, or display exactly the max number of characters of a line.
Users browsing this forum: Anthropic Claude Bot [bot] and 15 guests
