I flashed the Sonoff basic with R200 dev firmware and work with domoticz to control a light. I want to power on the Sonoff and the light is on. When I enable relay GPIO12 boot state to high, every time I power on it, the light turns on for 2 seconds then automatically turns itself off. I was suspicious it is caused by domoticz as the switch state is off in domoticz while the sonoff is turned on, then domoticz forced the state synchronization by sending off command to sonoff. But this approved to be wrong. I stop domoticz, the problem still exists.
I also tried to add a 1 second timer in the rule to set relay GPIO12 to high. But that is only executed after the light completed the initial on and off cycle.
What is wrong?
Tony
Sonoff enable relay GPIO12 boot state to high but it turns off after 2 seconds automattically
Re: Sonoff enable relay GPIO12 boot state to high but it turns off after 2 seconds automattically
The internal GPIOs are being known to flicker during boot. If this is a problem I suggest you try to use an IO expander (PCF8574 for example).
https://www.letscontrolit.com/wiki/index.php/PCF8574
You could also try to use GPIO 13 or GPIO 14 and see if they behave better. (I generally use GPIO 14 for my relays that I need to have non-flickering during boot)
Thanks for the quick reply.
I think the Sonoff unit has hardwired the relay to GPIO12 correct? So I can't use GPIO13,14 for its built in relay. IO extension board is not an option as I need to squeeze Sonoff into my wall switch concrete hole and no much room left. Is it possible to make some Sonoff board wiring change in order to use GPIO 14 to control its relay?
Sorry for confusing you. I was referring to a bare ESP unit. The Sonoff is hardwired, yes.
well theroretically it's doable, just a matterto find the GPIO12 trace, cut it, solder a jumper wire from the break to the GPIO14 pin of the ESP...
Users browsing this forum: No registered users and 37 guests
