Not sure if this is the right place to pull this, but having a problem with a basic sonoff. The problem is I used the flash tool to load ESPeasy V2.0.0 -dev11_dev_1024 onto a basic 1 M sonoff. I then follow instruction on adding wifi network then fill in the other fields until I got to "devices" where I added the switch to GPIO-12 (D6) for switch and the Button GPIO 0 (D3). I couldn't find how to add the relay? I rebooted and now can access everything but "devices". If I try to access "devices" it boots me out to the login screen for the password. Any help will be highly appreicated.
