Measure current with nodemcu and acs712
r16
#1 Post by r16 » 24 Sep 2017, 00:56
Hello guys.
Anyone use acs712? I have one but i dont find any code for read the measures , and to send via mqtt.
Anyone use ?
Drum
Re: Measure current with nodemcu and acs712
#2 Post by Drum » 24 Sep 2017, 07:28
I have never seen this before but from what I can find quickly it has an analog output range higher than the esp adc pin can handle without a resister divider or other module to convert it to digital.
Using an already supported module like pfc8591 or ads1115 should allow you to use it without modifying a plugin.
Be aware the modules I found quickly run on 5V, although the only datasheet I found said 2.5V vcc. Check to see output is not dependent on input voltage as this could cause inconsistant readings if input voltage is not consistant.
Users browsing this forum: Anthropic Claude Bot [bot] and 14 guests
