SSD1306 can't get it to work
hi there,
I have done several things with esp and espeasy so far and I am very happy with results. Today I have tried to get a SSD 1306 OLED up and running but I was not successfull.
In general it is easy to connect SDA and SCL and + / -
Then I did a i2c scan but nothing happens.. also tried to change SDA and SCL but still no luck. I have tried the same with a SSC 1309 but same problem.
I am on espeasy 2.0_Rev.11 (normal) - also tried (test), but no luck either...
does any one have an idea, why oled does not work at all?
regards
Karl
regards
Karl
Re: SSD1306 can't get it to work
Make sure the display is configured for I2c, many of these are not by default.
Also check the datasheet for the module to verify the voltage required.
If those do not resolve it, send screenshots of how you have it configured in EspEasy as well as a link to what you purchased, and schematic.
It really is not possible to troubleshoot without more information.
I have tried a ssd1309 now with ssd1306 settings and surprise, surprise 1309 is identified and works very well!
I will try to figure out why the ssd1306 doesn´t work
the 1306 display shows VDD and the 1309 shows VCC. VCC works well with 5V, maybe I've killed the 1306 by applying 5V. The datasheet for the 1306 says, 3.3V only
any experience out there with 5V on a 1306?
regards
Karl
regards
Karl
Looks like a successful killing....
From 1306 data sheet:
Power supply
o VDD = 1.65V to 3.3V for IC logic
o VCC = 7V to 15V for Panel driving
Power supply
Well all SD1306 module I've been using have a 3.3/5v regulator onboard (662K) in fact I'm happily running all of them 5v or 3.3v without any difference.
I doubt module in subject has differences thus I don't believe it's been fried by wrong voltage, maybe DOA...
I have at least 3 different versions of the ssd1306 module, 4 pin, 7 pin, 8 pin and adafruit feather shield. All are supposed to work on 3.3v. No problem with the 4 pin models I have or the adafruit shield. I could only get 1 of the others to work.
Unfortunately there are a lot of people making these modules. Quality is not always good.
I would try to find another. It could just be a bad module.
as it is quite cheap, i will go for a new one. i also have a 2.4" one and this one works fine...
many thanks
karl
many thanks
karl
I also have a SSD1306 with 7 pins, it should be full color according to the chinese webshop where I bought it.
https://photos.app.goo.gl/cU1maYoLaheKxdVc2 (front and back picture)
is there a possibility to get this working in ESPEasy ?
Regards,
Dirk
Regards,
Dirk
The 7 pins mean SPI + I²C interface. You must look at the back for the configuration (some Rs must be replaced to change mode). Normally this displays are blue or white or 2 color (yellow & blue). You better published the URL of the shop, where you bought it. Many of us have this display in use and is supported by ESPeasy.DirkTas67 wrote: ↑18 Oct 2017, 18:48 I also have a SSD1306 with 7 pins, it should be full color according to the chinese webshop where I bought it.
Regards,
Dirk
This is the exact webpage where i bought it.
https://nl.aliexpress.com/item/0-95-Inc ... 85282.html
That display seems to be SPI only.
Besides that it has 96 x 64 pixel so i assume it would run into problems with ESPEasy.
I'D recommend to stay with the 128x64 oleds with 4 pins like this:
https://nl.aliexpress.com/item/20Pcs-SN ... 1431cd53b4
Yep, it's only SPI. There is no interface selector on the back. And the resolution is in fact poor. Looks more like a LEGO graphics display....
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 30 guests
