My ESPs (2 of them) reboot after like 12-24 hours, i never saw one with an uptime over about 1500 minutes.
Sometimes they even Crash completely, so i Need to reset them by unplugging power
i see there is a syslog Feature, how could that be used ?
how to use syslog ?
Re: how to use syslog ?
1) Make sure you have a syslog server running in your local networkkr0815 wrote:i see there is a syslog Feature, how could that be used ?
2) Enter the IP addres of this server into the field "Syslog IP"
3) Set the syslog level to something between 1 and 4
I didn´t think it´s that easy, already have it running.
So Level 4 should bring most log Messages ?
Regardless what i choose between 1 and 4 the following is all i get?
(Same also for web and Serial Connection)
86726143 : WD : Uptime 1445 ConnectFailures 0 FreeMem 27256
86727153 : MQTT : Connected to broker
86727156 : Subscribed to: /Home/#
86733835 : DS : Temperature: 13.44 (28-ff-1e-19-82-15-3-e1)
86735696 : DS : Temperature: 13.56 (28-ff-cd-f8-81-15-3-d3)
86756152 : WD : Uptime 1445 ConnectFailures 0 FreeMem 27448
86757163 : MQTT : Connected to broker
86757168 : Subscribed to: /Home/#
86763838 : DS : Temperature: 13.44 (28-ff-1e-19-82-15-3-e1)
86765705 : DS : Temperature: 13.56 (28-ff-cd-f8-81-15-3-d3)
