I have a nodeMCU ESP8266 with new flashed ESP v2.0.0-dev12 (same behaviour recognized with dev11)
I have attached 3 pulse counters with around 4100-4200Hz each.
Every 60 seconds the three values are reported to a "volkszähler" server.
This works fine.
BUT there are a lot of spikes in the diagrams and I found out that these are caused by warm boots of the nodeMCU ESP8266.
They occur not regulary.
Sometimes it works one hour without any issue.
Sometimes it warm boots within one minute.
...and everything between these times.
It is no regular phenomen (then it could be something with a overflow of a variable, but it is not)
Any idea what can be the reason?
....maybe the power supply???? Currently it is a work bench test installation. I didn't check this. It runs on USB 5V from the computer.
Thanks and best regards,
Chris
What causes so many warm boots?
Re: What causes so many warm boots?
I have one unit attached to a USB UPS and that unit hasn't rebooted for 3 months. I suspect it being a power supply problem, not qualified to give more insight than that though.
Hello all,
It might be a power problem even if the one from grovkillen and some nodemCUs running here work fine.
This depends on the quality and length of the USB cable you use.
I have some USB cables that cause such problems. The wires inside are very thin so currrent peaks
for example if WiFi sends data may cause voltage dropping down.
Well cheap cables.... i got what i paid for. Ruskin's rule is everywhere.
You might try a "fat" cable with thick wires inside.
Or you may try a capacitor of 470µF or bigger from 3.3V to ground.
Anyways i'd recommend using a high quality power supply with at least 1,5...2 ampere.
If you're doing such workbench tests often in a long run you might consider
buying a lab power supply. If doing such things often it pays.
I agree on the power issue, especially because you are running it off a computer USB port, I have had a lot of problems with those. Get a wall-wart, cell phone chargers tend to work well for me.
I use some good size caps, 1000uF on my nodemcu and .22F 5.5v on others (actually really small). 1.5F runs an ESP-12F for a few seconds, but I think it is overkill. It is a little harder to add caps to the nodemcu, easier to use a good powersupply. I have mine on a breadboard so it is easy to plug in, but I also fried a diode at one point shorting the legs. Still works, I replaced the diode with wire.
Thank you for your feedback!
Yesterday night I moved from the workbench to the object of interest.
I installed two (will be three in the end) optical rpm sensors, wired it up, and powered it directly with a good quality 3A power supply with a fat short cable.
The installation works, but nothing changed regarding the warmboots.
20 warm boots within 9 hours.
Because it ran at night, no one could cause wobble contact or similar.
The behaviour is the same, no matter if I use a thin 2m USB cable powered by the computer or a short fat cable and a 3A power supply.
My feeling is, that it has nothing to do with the power supply.
Any Idea how to debug it?
How can I find the reason for the warmboots?
Chris
Chris
The pulse counter was not really designed for applications like this. It was developed and tested for slow pulse devices like gas/water/electric meters.themanfrommoon wrote: ↑07 Oct 2017, 11:06 I have attached 3 pulse counters with around 4100-4200Hz each.
Although counting higher frequencies may work, it produces huge amounts of ISR calls and puts a rather heavy load on the low level system.
It could just be that the ESP core watchdog kicks in because the main network core handling is delayed for too long periods
For real frequency counters, hardware counters should be considered. I'm not sure if the ESP8266 has any general purpose internal counters free to use.
Hi Martinus,
On the testbench I had a small fan with around 4000rpm and three optical sensors for testing.
In the final Installation I have a fans with a max. speed of about 1700rpm, but two reflector marks because of the mechanical balance, this means frequencies of 2x 1700rpm and in the ESPEasy a divider of 2.
So the frequency to count is nearly the same like on the testbench.
I read about the internal watchdog and the need for time for the core functions of the ESP8266.
For me your explanation of causing the warmboots sounds plausible .
Is there any chance to proof this?
Is there any possibility (like a logfile or a serial output) which I can have a look for and find the reason for the warmboots?
Any idea which hardware counter I can use for this job?
Chris
Chris
Depends a bit on the accuracy you need.
If you don't need very high accuracy you simply may use a binary divider/counter chip like a 74HC4024.
This chip is a 3.3V compatible 7-bit divider. You may feed it with the 4000 Hz pulses and grab
a f/2, f/4, f/8..... f/128 signal from the outputs. So this gives 2000Hz, 1000Hz, 500Hz.....31.25Hz.
Remember: The lower the pulse frequency is, the lower is the accuracy.
Please put a capacitor of 100nF (ceramic type) on 3.3V and GND as near as possible to the counter chip.
As the chip has all 7 outputs availlable it's possible to experiment and test to find a stable and accurate enough division level.
Atm i don't see a way to directly use a counter register inside the ESP.
Users browsing this forum: Anthropic Claude Bot [bot] and 16 guests
