Switch: can I send state only when changed?
manjh
#1 Post by manjh » 09 Oct 2017, 13:54
I have a rain sensor attached to one of my ESP units. It is configured as switch, and works OK.
The only problem is that it's state is transmitted to Domoticz periodically, regardless of state change.
I would prefer to have a transmission done only when the switch changes state!
Is this possible?
This is the current device configuration:
Re: Switch: can I send state only when changed?
#2 Post by grovkillen » 09 Oct 2017, 13:58
Put delay to "0", and it will only be sent when changed. It is even stated that the delay is optional (see you own screenshot). More info is found on the wiki.
manjh
#3 Post by manjh » 09 Oct 2017, 15:43
Ah, great when a solution is that simple....
Users browsing this forum: Anthropic Claude Bot [bot] and 19 guests
