serial port send data to Thingspeak
Hi All,
Im VERY new to ESPeasy so please excuse any stupid questions. I have a current prototype unit that consists of a PIC controller that is connected to an ESP 12E via the serial port. The PIC has a few sensors connected to it and sends this data to Thingspeak. Currently I use AT commands to accomplish placing the data on Thingspeak using an http GET request. I would like to use the ESP firmware because of it’s configuration functionality so my questions are………….
1. Can I use the serial port to send multiple channel values from the PIC to the ESP then to Thingspeak?
2. Are there any examples of how I would set ESPeasy up and an example of the string I would send to the serial port?
Ray
Ray
Re: serial port send data to Thingspeak
It depends on the mode and complexity of the serial communication, that you want to use.rayE wrote: ↑12 Oct 2017, 13:22 Hi All,
Ray
There are a simple Ser2Net plugin, which can be used with rules, as needed:
http://www.letscontrolit.com/forum/view ... net#p19201
If it is not enough, i am afraid you have to create your own plugin.
Thanks for the quick reply. I can tailor the protocol to whatever ser2net wants so that is not a problem. I will look at the ser2net plugin and hopefully get something up and running.
Thanks for the pointer.
Ray
Ray
OK, i made some progress on this today and did the following.
1. Flashed ESP Easy onto ESP-12E module.
2. Set all the basic settings to connect to my network.
3. Followed the instructions here to send data to thingspeak
http://www.letscontrolit.com/forum/view ... f=4&t=1175
4. Set up a ser2net device
5. using the following device settings i can send 2 system values to thingspeak at 20 second intervals and all is OK.
6. See the attachment pics for ser2net config details.
Now im stuck :-/ on 2 points (i think)
1. How do i pass a variable over the serial port to ESP Easy. I take it i would send a command like SerialSend followed by the value? i cannot find any documentation on serialSend?
2. Once i have the value in ESP Easy then would i set up some "rule" to pass this data to thingspeak?
Apologies for the complete "vagueness" on all of this but im at the bottom of a learning curve. Any pointers/examples/help is much appreciated.
TIA
Ray
TIA
Ray
- Device - serial server.png (17.34 KiB) Viewed 7648 times
- Devices.png (21.92 KiB) Viewed 7648 times
This is how i have set up Tools - Advanced
- Tools-advanced settings.png (18.36 KiB) Viewed 7646 times
Is this the direction i should be heading?
TaskValueSet Rules Set values on a Dummy Task device TaskValueSet <task nr>,<value nr>,<value/formula>
As i know, the only option to output is to Publish raw data from serial port to the MQTT server, or Thingspeak.rayE wrote: ↑13 Oct 2017, 09:37 Now im stuck :-/ on 2 points (i think)
If the Ser2Net device is named SerialRAW, then:
On SerialRAW do
Publish %sysname%/SerialRAW,[SerialRAW]
You can check the Ser2Net source code directly:
https://github.com/letscontrolit/ESPEas ... er2Net.ino
There is a closed bug with a similar task, so i am not sure, that it will work as you want:
https://github.com/letscontrolit/ESPEasy/issues/514
Thanks for the information. I will give it a try today
Ray
Ray
My solution to posting data (multiple fields in one go) to thingpeak through the ESP serial port is here.
viewtopic.php?f=6&t=3642
Ray
Ray
